General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Radiator Pressure Test
Old Mar 21, 2006 | 07:52 AM
tomsblazer's Avatar
tomsblazer is an unknown quantity at this point
Default Radiator Pressure Test
I purchased a used radiator from the local junk yard. It looks better than the one presently on my Blazer.
I want to pressure test all 3 cores. I know the engine cooling part has a 15Lb. pressure cap, so maybee 20Lbs is a good test value.
How much pressure do I apply to the engine oil cooler? I know my dash gage reads up to 60Lbs on a cold start.
I have no clue on the transmission pressure.
Old Mar 21, 2006 | 03:29 PM
4lowlife's Avatar
Default RE: Radiator Pressure Test
Well, if the radiator fails the gauge test.........wouldn't it be junk? It wouldn't matter which cooler was leaking.
I you decide to keep it. block the holes for the other coolers and install aftermarket aux coolers (oil, and tranny) instead of using the ones in the rad.
Old Mar 21, 2006 | 11:45 PM
RacerX_96's Avatar
RacerX_96 is an unknown quantity at this point
Hi,
I wouldn't recommend going over say 16-18 lbs on a used radiator. Depending on who made it, their test specifications (when new) where likely not much higher than that. Just my $0.02.
Bob
yeepman2
Mar 12, 2011 06:13 PM
stflr
Aug 18, 2010 09:26 PM
KingKtulu
Jul 2, 2010 11:39 AM
bigdaddykane93
Jan 4, 2010 12:03 PM
zombiewoof
Feb 11, 2008 10:33 AM
