General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
rear brake rotor and diff aspect ratio
Old Nov 23, 2006 | 08:31 AM
Marcin's Avatar
Marcin is an unknown quantity at this point
Default rear brake rotor and diff aspect ratio
Hi
I try to buy rear brake discs and I found two different Delco part numbers for it depending on rear differential aspect ratio. How could I determine what aspect ratio is in my car and what is the difference between rotors?
Cheers, Marcin
Old Nov 23, 2006 | 12:21 PM
rooster's Avatar
rooster is an unknown quantity at this point
Default RE: rear brake rotor and diff aspect ratio
there are identification and manufacture codes stamped on the right rear axle tube on the front side of the tube. they contain info on rear axle ratio, differential type, manufactor and build info
Old Nov 23, 2006 | 05:59 PM
Marcin's Avatar
Hi
I found on AC Delco web site that for 2000 year 4WD Blazer they have 2 different rear brake discs but which one to use depend on rear axle ring and not on rear axle ratio.
I have found RPO GU6 in my glove box so I have had axle ratio 3,42. To read anything on my axle tube was impossible .
AC Delco web says to use differet rotors when axle is saginaw. I can see some RPO codes for saginaw but no one is used in my car so I hope I have no saginaw rear axle. The conclusion is to use standard rear brake rotors for 4WD, am I right? Or maybe I made a mistake?
Marcin
Old Nov 23, 2006 | 06:16 PM
Could you link to this site???
I don't know what the rear end ratio would have to do with the rear drum brakes, but a quick search on the Advanced Auto website for a 2000 Blazer shows quite a few choices when looking at Raybestos, but Bendix only shows one. The Raybestos rear rotors show choices for the 3.42 axle ratio and for the 3.73 axle ratio... Shouldn't make a difference...
Only thing I can think that 'may' be different would be the ZR2 axles vs. all of the rest of the blazer axles... The ZR2 has a larger axle.
Old Nov 23, 2006 | 06:25 PM
Marcin's Avatar
Hi
They told me at shop that difference is in axle ratio. But at AC Delco I find this http://tinyurl.com/y36jud which shows the difference not for axle ratio but for saginaw axles. For saginaw I can find RPO, etc...
I decided to buy rotors and check but I hoped AC Delco is right.
Marcin
Old Nov 23, 2006 | 06:32 PM
Yup, now that's the difference I expected to see, not in the rear end ratio... Any non-ZR2 blazer has a 7.625" ring gear. But comparing part numbers, they are the same... LOL
Old Nov 23, 2006 | 06:38 PM
Marcin's Avatar
Sorry I cant understand.
I can see two different rear brake discs:
177-843 for:
With RPO 7.625 R/GR SAGINAW-AMERICAN
and
With RPO 8.50/8.625 R/GR SAGINAW-AMERICAN AXLE
and also rotor 18A875 for:
ROTOR ONLY 4 WHEEL DRIVE
What Blazer is ZR2? In my understandig if there is no RPO for SAGINAW-AMERICAN the proper rotor should be 18A875? Is'n it true?
Marcin
Old Nov 23, 2006 | 06:42 PM
Those different PNs are for different tier rotors (ie. one is more expensive and better quality). I would suspect the durastop (PN 18A875) rotors to be cheaper, but either will work equally as well.
Old Nov 23, 2006 | 06:46 PM
Marcin's Avatar
So if they are the same size they could work in my car and no metter which one I buy? Great! It makes me happy becouse in Poland I can easily buy front brake rotors but only one seller has rear rotors. Thanks!
Marcin
Old Nov 24, 2006 | 12:38 AM
Crashes's Avatar
Crashes is an unknown quantity at this point
The bigger ring gear (8.50) is the ZR2 rear axle size.
If you dont have a ZR2 get the 7. whatever, if you do get the 8. whatever.
Blazer_boy
Jan 5, 2013 09:33 PM
biggin
Feb 24, 2011 11:18 AM
SCPratt
Feb 14, 2011 11:09 PM
dagda
Jan 12, 2010 06:37 PM
00Blazer1
Apr 30, 2009 07:05 AM
