rear driveshaft help
i have a 1988 k5 4x4 i put a 6in suspension lift on it and i recently put a 1in block in the back just to level it up..but now the rear drive shaft is rubbing the yolk going into the transfer case..what are some of the things i could do? i do plan on getting a larger spring lift and then i still dont kno what to do about the driveshaft..
You are probably going to have to go to a high-angle driveline inorder to accomodate your new angles. The pinch point will always be at your transfer case unless you go with a total drop case.
gitch93
Jan 23, 2013 04:51 PM
iamchevyman5
Dec 28, 2011 01:52 PM
tony991
May 14, 2011 03:49 PM
stevelknievel
Jul 17, 2007 08:13 PM
Blasir
Feb 7, 2007 09:07 PM
1988, 79, blazer, chevrolet, chevy, drive, driveshaft, installation, k5, rear, reardriveshaft, shaft
