General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Screeching
Old Oct 26, 2006 | 02:35 PM
saliheen's Avatar
saliheen is an unknown quantity at this point
Default Screeching
I have a 1998 chevy blazer and when I push the brakes there is a screeching sound, sounds like th e disc for the brakes, what can be causing this?
Old Oct 26, 2006 | 03:01 PM
fnirish's Avatar
fnirish is an unknown quantity at this point
Default RE: Screeching
Sounds like your pads have worn down to the metal. Pull the wheel and inspect - if its making metal to metal contact it could ruin the disc.
Old Oct 26, 2006 | 05:44 PM
Actually, there is a squeaker on the pads that will cause this noise when the pads have worn down far enough. They are there to prevent the pad from completely wearing out before you get around to fixing it. Basically they are meant to be annoying enough that you'll want to fix them.
Boopappa
Jun 25, 2011 09:23 AM
Mark_D
Apr 29, 2011 11:40 PM
WesX
Nov 9, 2009 03:50 PM
kareem840
Performance & Brainstorming
May 9, 2009 09:59 PM
2000LT
Oct 5, 2006 11:35 AM
