General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Searching Through RPO codes
Old Jul 6, 2006 | 01:09 AM
ceanern's Avatar
ceanern is an unknown quantity at this point
Default Searching Through RPO codes
Was going through my RPO codes and was wondering what exactly was meant by Gas, 6 cyl, 4.3L, CPI, V6, 90 Deg, HO the RPO code is L35 I understand basically Everything as far as gas, 6 cyl 4.3L CPI and V6 and HO. Just not sure about the 90 Deg. Will probably have more as I search through everything on my vehicle Just the 90 Deg has be curious as to what exactly that is.
Also Curious about this one. Z85 Says Z85 33656 P CHP R Chassis Package Increase Capacity 911114ETT
Thanks
Old Jul 6, 2006 | 02:03 AM
ceanern's Avatar
Default RE: Searching Through RPO codes
Here is my list of RPO Codes. I missing some numbers because of them being partially wiped off. I'm trying to figure out what my rear has for limited slip or what not.
1GNCT18W2XK168618 100.5
AJ1 AM7 AP9 AU0 AU3 AV5 AXP A31 B30 C25 C61
C60 DD0 DD8 DH2 DK7 D55 EVA E55 FF4 FK3 GU6
JC1 K18 K34 K60 L1N? L35 M30 NC1 NG1 NP1 NP5
N33 N40 PA3 P16 QBF RSA RYJ SLM T61 UL0 UP8
U16 U73 U89 VXS V54 V73 XBF X88 YBF YC3 YD3
YD5 YD6 ZBF ZM8 ZQ3 ZQ6 ZY1 Z85 1SC 12H 121
41U 6WJ 7WJ
BC/CC U 85555 12H
Old Jul 6, 2006 | 08:25 AM
90 degree is the angle which the V in the V6 forms. The 4.3L is a 90 degree v6. The 2.8L is a 60 degree v6, which is narrower and why the bellhousings on the 2.8L is different.
As far as the rest of them... Well, there are several RPO decoders that have been posted about before. Try searching for them.
Old Jul 6, 2006 | 12:19 PM
ceanern's Avatar
Went through the RPO last night. Pretty much decoded all of em. Just wasn't sure what was meant by the second RPO Code the Z85. The description is a bit vague as to what exactly it means. OR atleast I'm thinking it is a touch vague Thanks for the info on the motor.
Old Jul 6, 2006 | 01:04 PM
Z85 is the heavy-duty trailering suspension which basically is just higher rate rear springs from what I understand.
Old Jul 6, 2006 | 02:03 PM
ceanern's Avatar
Alright. I need new rear leafs anyway. Off roading once and made start flatten out. where is a good place to get replacement leafs at?
Old Jul 6, 2006 | 02:35 PM
Don't know about down near you, but near me, I have Thruway Spring which will custom make a set of springs for any application to whatever specs you want them to be at. Their leaf springs are only a bit more expensive than buying replacements from the dealership.
Old Jul 6, 2006 | 02:37 PM
ceanern's Avatar
I have a place near me that does the same They wanted like 150 or something like that for just one side plus labor if I remember correctly.
Old Jul 6, 2006 | 06:57 PM
2klt's Avatar
2klt is an unknown quantity at this point
Document ID# 328637
1999 Chevrolet/Geo Blazer - 2WD
RPO Code List
AA3
Windows: Deep Tint 1/4 Window; Light Tint Rear Window
AA0
Seat Adjuster: Power/Memory, Eight-Way, Two-Position
AG1
Seat Adjuster: Power, Six-Way
AG2
Seat Adjuster: Pass, Power, Six-Way
AH8
Seat Adjuster: Pass, Power, Eight-Way
AJ1
Windows: deep Tint, all Except W/S and DRS
AM6
Seat: Front Split, 3 Passenger, Center Armrest
AM7
Seat: Rear Folding
ANL
Sales Package: Air Deflector and Fog Lamps
AN3
Seat: Adjustable Lumbar Support
AP9
Net: Convenience
AU0
Entry System, Remote Keyless
AU3
Lock: Side Door, Electric
AV5
Seat: Front Bucket, High Back
AXP
Vin Ident Position, Multi-Purpose Vehicle, Requires AM7 Rear Seat
A28
Window: Sliding Rear, Full Width
A31
Window: Power Operated, Side Doors
A52
Seat: Front Bench
BG9
Covering: Floor, Rubber
B30
Covering: Floor, Carpet
B32
Floor Mats: Front
B4U
Performance Package: Sport
B84
Molding: Exterior YC5, YC6, and YC7
B94
Appearnace Package: Bravada, Gold Package Content
CF5
Window: Sliding Electric Sunroof
CTB
Appearance Package: Chevrolet "Trailblazer" Sport
C25
Wiper System: Rear Window
C3A
4400 Lbs. GVW Rating
C3G
4450 Lbs. GVW Rating
C3T
5350 Lbs. GVW Rating
C42
Heater: Deluxe Outside Air
C5A
4900 Lbs. GVW Rating
C5C
5000 Lbs. GVW Rating
C5D
4600 Lbs. GVW Rating
C5T
4200 Lbs. GVW Rating
C5X
4650 Lbs. GVW Rating
C6F
5150 Lbs. GVW Rating
C6I
4850 Lbs. GVW Rating
C60
Air Conditioning: Front, Manual Controls
C68
Air Conditioning: Front, Automatic, Electronic Controls
DAY
Plant Code: Moraine, OH GM T&B
DC4
Mirror: I/S, R/V, Tilt, w/ Dual Reading Lamps
DD0
Mirror: O/S, LH & RH, Rem. Control, Heated, LT Sensitive, Aux. Wide Angle, Color
DD6
Mirror: I/S, R/V, Light Sensitive, w/Dual Reading Lamps
DD8
Mirror: I/S, R/V, Light Sensitive, Requires Roof Console and DK2
DH2
Mirror: I/S, Sunshades w/Dual Blades, Illum., LH & RH
DH6
Mirror: I/S, Sunshade, Illum., LH & RH
DK2
Mirror: O/S, LH & RH, Rem. Control, Heated, Aux. Wide Angle, Color
DK7
Console: Roof, Interior, Custom
DK8
Console: Roof, Interior, Deluxe
DR4
Mirror: O/S, LH & RH, Rem. Control, Heated, Dual Pwr. Folding, LH LT Sensitive, Aux. Wide Angle, Color
D07
Console: Floor, Interior, Custom
D34
Mirror: Inside, Sunshade
D44
Mirror: O/S, LH & RH, Man. Control, Aux. Wide Angle, Color
D55
Console: Front, Floor
D81
Spolier: Aero Wing
D88
Stripe: Decal, Sport
D96
Body Stripe: Side, Upper
D98
Stripe: Accent
E24
Door: Side Cargo
E55
Body Equipment: End Gate
E62
Body Equipment: Stepside
E63
Pickup Box: Fleetside
FE9
Certification: Emission, Federal
F46
Chassis: All Wheel Drive
GT4
Rear Axle: 3.73 Ratio
GT5
Rear Axle: 4.10 Ratio
GU4
Rear Axle: 3.08 Ratio
GU6
Rear Axle: 3.42 Ratio
G67
Level Control: Automatic
G80
Rear Axle: Positraction
JC1
Brake: Vac. Power, 4 Whl Disc, 5500 Lbs.
JM3
Brake Booster: 260 MM, Tandem High Flow
KA1
Heater: Seat
K05
Heater: Engine Coolant
K18
Reactor System Air Injection, Electric
K34
Cruise Control: Automatic, Electronic
K60
Generator: 100 Amp
LF6
Engine: 4.3 Liter V6, CPI
LIN
Plant Code: Linden, NJ
LN2
Engine: 2.2 Liter L4, MFI
L35
Engine - 4.3 Liter V6, CPI
MW2
Transmission: 5-Speed Manual, 76mm (NVG 1500)
M30
Transmission: Hydra-Matic 4L60-E, 4-Speed Automatic
M50
Transmission, 5-Speed Manual, S4WD, 85 mm (NVG 3500)
NB7
Emission System: California, TLEV
NB8
Old Jul 6, 2006 | 08:33 PM
2klt, please try to refrain from posting information in this manner. Your post isWAY too long. A much better thing to do would have been to link to the thread were links to the various RPO decoders has been done.
Regular Production Option (RPO) Codes
See how clean and simple that was...
93LT
21
Apr 18, 2017 07:49 PM
FireInMe17
Jan 2, 2011 04:31 PM
Cavalier z24
Feb 24, 2009 11:16 AM
Roudy4x4
Feb 20, 2009 03:55 PM
walkingtall
Nov 1, 2006 01:26 PM
