General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Slight Noise in CMFI 4.3
Old Aug 6, 2006 | 01:08 AM
92ChevyBlazer's Avatar
92ChevyBlazer is an unknown quantity at this point
Default Slight Noise in CMFI 4.3
First off the vehicle is a 1995 S10 pickup but I'm posting this because its the best board Ive found and its the same driveline. The 4.3 has a 115000 miles on it and it emits a rather quiet popping sound. The noise occurs if u rev the truck to 1800 in park but it is the worst right as the revs start to increase and when the rpms return to idle. The noise also occurs whenever the a load is put on the engine. The motor still sits in at 200 degrees and has plenty of power. Ive checked the valvetrain and nothing there appears to be causing the problem. and I plan on checking the timing chain next but i was wondering if anyone had any input before i do all that work. I also talked to two mechanics about the issue and one said it was wrist pins? and the other said just drive it.
Old Aug 6, 2006 | 03:59 PM
Nations81's Avatar
Nations81 is an unknown quantity at this point
Default RE: Slight Noise in CMFI 4.3
Not sure what the problem could be but try Lucas' oil substitute. replace a court of oil with that next oil change it might free stuck parts or cause them to slide arould smoother in the engine.
craigzter
Feb 15, 2010 05:42 PM
blazerman9497
Jan 15, 2010 08:50 AM
mikol23
Apr 13, 2007 08:11 AM
jaykeMURD
Jun 22, 2006 08:13 PM
Mr. Chevy
Apr 21, 2006 11:46 AM
