General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Steer mounted radio control???
Old Jul 24, 2006 | 01:52 PM
TN_TrailBlazer's Avatar
TN_TrailBlazer is an unknown quantity at this point
Default Steer mounted radio control???
I have the 2000 TrailBlazer with steering wheel mounted radio controls. The right side, Mute/Volume work and light up at night; the left side Program/Scan work fine, but do not light up at night?? The fuses are fine. How do I find out if it is the Little lightin the switch, and how do i replace it? Thanks
Old Jul 24, 2006 | 01:56 PM
Default RE: Steer mounted radio control???
Most likely it is the LED in the switch itself that has burnt out. Only way to tell would be to open the switch up and test for power at the terminals of the light. If you have power, then the light needs replacing.
Old Jul 24, 2006 | 02:03 PM
XBlazer01's Avatar
XBlazer01 has a spectacular aura aboutXBlazer01 has a spectacular aura about
When i got my truck mine was out. Uh I believe u have to take it to the dealership to get it replaced.
Old Jul 24, 2006 | 03:25 PM
If the dealer can replace it, more than likely, you can replace it cheaper if you are willing to do the work.
Old Jul 25, 2006 | 03:23 AM
Chevy Lover's Avatar
From what I can see, it appears the control switch is a sealed unit. The steering wheel has to be removed and the switch is released by prying on plastic tabs from the back.
[IMG]local://upfiles/2910/0F7296398B69409280CC31ABC632B232.gif[/IMG]
Old Jul 25, 2006 | 03:55 AM
I would have to assume that there is a small led inside that illuminates the buttons. A soldering pencil may be required to replace the led, but it is not all that difficult.
Here's what I would do, price out the switch from the dealership if you can't find one in a junk yard. If it isn't all that expensive from the dealership, then try to get it apart and replace the light. If you replace the light without breaking anything, good job. If not, just buy a new one.
And I believe that his steering wheel looks similar to this:
And does not have the controls actually in the spokes of the wheel as depicted.
If you get them off, snap some pictures of them from all sides. I believe you can finess the outer cover off to expose the inner circuit board.
Red 96'
Nov 28, 2011 10:09 PM
bluereign
Oct 13, 2011 09:27 PM
pollocksn
Jun 29, 2011 03:16 PM
racsan
Tires and Wheels
Feb 17, 2011 01:44 PM
k5bmr
Oct 10, 2010 06:46 PM
