Tranny takes a while to get into gear
When cold, my tranny takes about 5 seconds to get into gear. Its a new tranny with about 24k miles on it, 700-r4. Any ideas? I think this is a problem for older vehicles, because all my friends older trucks take a while to get into gear, such as reversing and being able to put it in drive before you stop and by the time you stop it goes into gear.
ORIGINAL: 00blackblazer
24,000 miles have your changed the fluid and filter yet? they are due to be serviced every 15000 miles.
In heavy city traffic where the outside temperature regularly reaches 90*F (32*C) or higher.
In hilly or mountainous terrain.
When doing frequent trailer towing.
Uses such as found in taxi, police or delivery service.
I've always changed mine around 35-40k miles. Install a drain plug the first time you have the pan off and then enjoy quick/easy fluid changes for the rest of your vehicles life. Being a closed system, the only thing to clog the filter is the friction parts in the trans. If you lost enough clutch material to clog the filter, you'll have more issues to deal with than just swapping out the filter.
project85
Feb 1, 2015 08:32 PM
kyboyyy89
Oct 27, 2014 07:50 PM
DoubleDouble
Apr 13, 2011 11:34 AM
