General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Tranny takes a while to get into gear
Old Nov 23, 2006 | 01:39 PM
88s10Blazer's Avatar
88s10Blazer is an unknown quantity at this point
Default Tranny takes a while to get into gear
When cold, my tranny takes about 5 seconds to get into gear. Its a new tranny with about 24k miles on it, 700-r4. Any ideas? I think this is a problem for older vehicles, because all my friends older trucks take a while to get into gear, such as reversing and being able to put it in drive before you stop and by the time you stop it goes into gear.
Old Nov 23, 2006 | 04:43 PM
Canadian88's Avatar
Canadian88 is an unknown quantity at this point
Default RE: Tranny takes a while to get into gear
Mine is a little slow as well, I always thought it was the torque converter or something but it isn't. I have a four speed auto btw.
Old Nov 23, 2006 | 05:25 PM
00blackblazer's Avatar
00blackblazer is an unknown quantity at this point
24,000 miles have your changed the fluid and filter yet? they are due to be serviced every 15000 miles.
Old Nov 23, 2006 | 05:56 PM
ORIGINAL: 00blackblazer
Let me state that the change interval is 15k when the vehicle is used under the following conditions:
In heavy city traffic where the outside temperature regularly reaches 90*F (32*C) or higher.
In hilly or mountainous terrain.
When doing frequent trailer towing.
Uses such as found in taxi, police or delivery service.
I've always changed mine around 35-40k miles. Install a drain plug the first time you have the pan off and then enjoy quick/easy fluid changes for the rest of your vehicles life. Being a closed system, the only thing to clog the filter is the friction parts in the trans. If you lost enough clutch material to clog the filter, you'll have more issues to deal with than just swapping out the filter.
Old Nov 24, 2006 | 03:47 AM
Chevy Lover's Avatar
I like your thinking Kyle.
If you have a drain plug, there's bound to be less procrastination....
I'm a firm believer in changing fluids regularly.
project85
Feb 1, 2015 08:32 PM
kyboyyy89
Oct 27, 2014 07:50 PM
DoubleDouble
Apr 13, 2011 11:34 AM
rob1621
Mar 21, 2008 01:23 PM
