General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
transmission and fuse
Old Sep 12, 2006 | 12:41 AM
mscott03's Avatar
mscott03 is an unknown quantity at this point
Default transmission and fuse
I posted someone about this a little bit back but still don't know what to do. The square that outlines the P R N D 1 2 3 is not present and someone suggested that a fuse was blown. Does anyone know where this fuse is? somewhere around the tranny? or in a wire running from the tran up to the front? Just curious to know if anyone has had any past experience with this and knows where the wiring is..
Old Sep 12, 2006 | 03:33 AM
Chevy Lover's Avatar
Default RE: transmission and fuse
I think the problem is probably a faulty cluster, but I do see three fuses that power the cluster. Fuses #4, #11 and #19, all are 10amp fuses.
[IMG]local://upfiles/2910/A65ADA2C48F04FD1A365B7FF1770A432.gif[/IMG]
Old Sep 12, 2006 | 09:56 PM
mscott03's Avatar
I don't think it has anything to do with the cluster - but I'll check that too - I have a feeling it has more to do with the wiring that goes to the tranny.
Old Sep 12, 2006 | 10:51 PM
gserve's Avatar
gserve is an unknown quantity at this point
Is it a 4 wheel drive? I have a 2000 with the 4 button transfer case. I was troubleshooting a 4 wheel drive problem and I pulled the 4 wheel drive fuse #15 on the inside fuse panel. In doing so the 4 lights on the buttons went out but I noticed when I shifted the tranny with the fuse removed that the box around the PRND12 was not lit when this fuse was pulled. This was a 10A fuse.
Old Sep 14, 2006 | 02:33 PM
mscott03's Avatar
I checked that and the fuse was fine. The other thing is I can put it into 4WD and it engages, so that cant be it.
Old Sep 15, 2006 | 01:33 AM
Did you check all the fuses, including the ones I mentioned?
I really don't think it has anything to do with the trans.
Old Sep 16, 2006 | 04:36 PM
mscott03's Avatar
I did check all the fuses. I dont think its the trans either - I just think that theres gotta be a fuse or some electrical short with the connection that goes to the transmission..
Joann
Oct 14, 2013 10:33 AM
AustinBlazer
Jun 4, 2013 10:35 AM
patitur77
Aug 4, 2012 11:35 AM
wallacereid
Jan 9, 2012 12:34 PM
champ186dc
Jan 9, 2010 10:34 AM
