General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
U Joints?
Old Aug 10, 2006 | 04:20 PM
sktdarkstar8's Avatar
sktdarkstar8 is an unknown quantity at this point
Default U Joints?
I have a 97 Blazer 2dr and its not a 4X4.. everytime i shift from park to drive it makes a big clunk noise.. also when i start to pull away from a stop it makes this rele loud noise like a slashing sound then goes away ones im up to speed.. i dont know what it is but my best guess is that its the u joints.. if any1 knows plz help!!
Old Aug 10, 2006 | 08:02 PM
lunatic_magnet's Avatar
lunatic_magnet is an unknown quantity at this point
Default RE: U Joints?
if it was a clunk when shifting it would be a trans mount...
from the sound you describe that definately sounds like u-joints, and it sounds like theyre BAD. i'd get that taken care of ASAP.
Old Aug 10, 2006 | 09:35 PM
also when im in park then shift to drive then to reverse u can see the pinoin rotate without the truck moving.. thats when the clunk acures.. is it play in the pinion gear and ring.. also is it repairable to do myself..?? help!
Old Aug 11, 2006 | 06:06 AM
Chevy Lover's Avatar
You're going to have some rotation of the driveshaft due to the fact that there is some play built in to the transmission, and differential. When you add up the play in both you'll see that in the driveshaft as all play combined.
You might want to check that the yolk on the rear differential is tight. If the splines are worn then it would have exessive play and possibly cause a clunk.
Another thing to check is worn universal joints or a loose pinion nut.
So there's a couple of ideas to look at.
Hope this helps
Old Aug 11, 2006 | 06:50 AM
if the pinion nut is loose you can try tightening it but usually if it gets that bad youve done damage to parts in the rear.
Old Aug 11, 2006 | 04:30 PM
Basslady's Avatar
Basslady is an unknown quantity at this point
I remember that sound well, it started off low then gradually got louder over a period of a couple months ... It was my rear U joint.
LoLoS10Blazer87
Suspension Tech
Sep 19, 2008 07:43 PM
tom1337
17
Mar 12, 2006 10:44 PM
TDQ
Suspension Tech
Jan 9, 2006 01:50 AM
alexbtango15
Suspension Tech
Jan 7, 2006 01:06 AM
hdlogistics
Suspension Tech
Dec 2, 2005 10:53 AM
