General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
update hood will open
Old Jun 15, 2006 | 03:40 PM
bat119's Avatar
bat119 is an unknown quantity at this point
Default update hood will open
if pull your hood release and the hood won't open put away the cutting torch, take a 13mm socket with a swivel and undo the two bolts under the hood latch the hood will then open. On my 99 Blazer the end of the cable came out from its slot under the hood and if this happens you can pull on the cable until it breaks and the hood will not open (I broke mine) to prevent this from happing to you take a wire tie and secure the cable end to the latch.
Old Jun 15, 2006 | 06:37 PM
Dory's Avatar
Retired Super Moderator
Dory is a jewel in the roughDory is a jewel in the roughDory is a jewel in the rough
Default RE: update hood will open
nice! and thank you.... always helps to have stuff like this handy if it should happen to someone else here.
chris015
Feb 14, 2012 10:20 AM
sprbld417
Apr 25, 2011 07:28 PM
skitzobmxr
Dec 16, 2006 07:07 PM
Hanr3
Sep 11, 2006 02:10 PM
bat119
Jun 13, 2006 11:15 AM
