General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
water sound out of the dash?
Old Feb 19, 2006 | 01:31 PM
Blazer1305's Avatar
Blazer1305 is an unknown quantity at this point
Default water sound out of the dash?
I had the water sound go on for a while, then it went away. Truck started to over heat so i had to add coolant. My radiator was all filled with dirt and stufff that doesnt belong in a radiator. Did the whole flushing of the system and my mechaninc said not to use dex-cool antifreeze. I was just wondering what that water noise is?
[IMG]local://upfiles/1380/39C58F6D0870446BBCA66B92691679B4.jpg[/IMG]
Old Feb 19, 2006 | 03:34 PM
ivannj's Avatar
ivannj is an unknown quantity at this point
Default RE: water sound out of the dash?
Since you had low antifireeze it made bubbles and that was the noise which was coming from your heater core.
Old Feb 20, 2006 | 12:52 PM
gsmollin's Avatar
gsmollin is an unknown quantity at this point
The sound was air in the antifreeze. Dex-cool does not tolerate air, and forms a sludge substance that you saw in your radiator. It will also rust the engine, and you should also see the rust in the overflow. The usual GM fix at this point is a radiator acid flush. Google dexcool and GM and blazer and you can see a pile of information on this. the GM service bulletin for the acid flush is also posted somewhere on Yahoo.
ABSLT
Dec 7, 2011 02:03 PM
chvyblazer00
Jan 30, 2011 06:56 PM
Flob1954
Apr 13, 2010 12:28 AM
drefda
Jul 13, 2006 05:05 PM
Blazer1305
Dec 1, 2005 06:49 PM
