General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Water poured out of the dash! Help!
Old Jul 13, 2006 | 10:33 AM
drefda's Avatar
drefda is an unknown quantity at this point
Default Water poured out of the dash! Help!
Yesterday, I got in my Blazer (96 4dr 4wd) and I made a right turn. As I was turning, water started pouring out of the bottom of the dash and onto the carpet on the passenger side. It wasn't antifreeze, it was water. Like a cup or so. It was raining heavy but that should not have anything to do with it. When I turn on the a/c sometimes I get a weird odor. The window fogs slightly sometimes but not to the point where I have to wipe it. I have a feeling it's the Heater Core but I am not sure. I've had cars where the heater core was leaking and I don't get the same exact symptoms. Like I said, water poured out and not antifreeze. It has dexcool and what came out was clear with no odor. I don't want to damage anything but the core replacement looks like one hell of a job. What could it be? Do I have to take my dash apart? NO!!!!!!!!!!!!!!!!
Old Jul 13, 2006 | 10:43 AM
Default RE: Water poured out of the dash! Help!
Have you ever had your windsheild replaced? I just ask because this exact same thing happened to my wife's BRAND NEW Malibu. I backed it out of a parking spot on a pouring rainy day and about a gallon of water poured out from under the dash on the passenger side and it was caused by an incorrectly installed windsheild.
Anyway, it could also be a blocked drain on the A/C evaporator housing. The best way to access this is to pull off the passenger side inner fender to have complete access, then using compressed air, blow up through the hole in the bottom of the case against the firewall. You could also pour water down into the air duct and see if it drains out properly...
As far as odor out of the vents, I had posted a fix for this awhile back... I'll have to see if I can find it...
*EDIT* - Here ya go:
A/C Evap Core Odor - Here's the fix!
Old Jul 13, 2006 | 11:46 AM
hillbillyinOhio's Avatar
ORIGINAL: drefda
I knew I put my beer down somewhere, just couldn't remember where. sorry.
Old Jul 13, 2006 | 02:02 PM
Dory's Avatar
Retired Super Moderator
Dory is a jewel in the roughDory is a jewel in the roughDory is a jewel in the rough
ORIGINAL: hillbillyinOhio
my god... i think i finally figured out who our comic releif is going to be around here....
Old Jul 13, 2006 | 05:05 PM
MsRandi's Avatar
MsRandi is an unknown quantity at this point
My blazer is older but I have a hole were the botom vent cal rusted out. just in front of the windsheild.
Flob1954
Apr 13, 2010 12:28 AM
bklahl
Jan 20, 2007 11:39 PM
picken_grass
Aug 1, 2006 04:54 PM
Blazer1305
Feb 20, 2006 12:52 PM
Blazer1305
Dec 1, 2005 06:49 PM
