General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Wiper, radio Question
Old Mar 16, 2006 | 06:53 AM
sting_da_man's Avatar
sting_da_man is an unknown quantity at this point
Default Wiper, radio Question
I bought a 88 s-10 blazer. the Cd player kept sgorting out, so the other day I went out tried to find the short, I took the fuse out of it, and also checked wiper fuse,among others, Still the radio has a problem, but when I went to use my wipers they didnt work(yes I put the fuse back in). but you can hear the motor running for them, but they dont move, I cant figure out what happened. Then I changed out Cd players to check and see if the player was the problem, it wasn't, and Now I got a cd player not working right, plus the wipers dont work now. Need Major Help! My G/f is scared to drive it now, affarid something else might go on her while driving it!
Old Mar 16, 2006 | 06:59 AM
Default RE: Wiper, radio Question
another question, what is the Harness under the stearing wheel, mounted to the dash trim to the right side of the stearing wheel? just wondering?
Old Mar 21, 2006 | 12:41 AM
Johnnyboy's Avatar
Johnnyboy is an unknown quantity at this point
If you can hear your wiper motor running then it's just a fluke because you removed the fuse. That would have nothing to do with the wipers not working if the motor is running. Look through the cowl grill & see if the rod came off the wiper motor, & that the motor is rotating. If it is then you need to remove the cowl & reattach the rod to the motor assembly. As for your CD player it might not be working. I have a 94 & the CD player doesn't work either & I only get about 3 stations that come in clear on the radio!! I need to buy a new one, so do you!! crap happens As for the harness, are you talking about the connector near the bottom of the steering column? You might be looking at the DLC (diagnostic link connector) that is attached to a harness.
Helter80
Jun 14, 2013 08:34 PM
bowtie-72
Feb 19, 2012 10:36 PM
dan_t
Nov 25, 2010 08:35 PM
iamchevyman5
Nov 7, 2010 01:20 AM
black19
Jun 22, 2006 03:35 PM
