TrailBlazer GMT360/GMT370 (2002-2009) Tech Have a 2002-2009 Trailblazer, Envoy, Bravada or Rainier? Post your general tech questions here.
03 trailblazer fan clutch
Old 11-11-2007, 10:04 AM
1lionsfan's Avatar
1lionsfan is an unknown quantity at this point
Default 03 trailblazer fan clutch
i have a 03 trailblazer w/ a fan clutch it roars when you go down the road so i changed it but it seem to disengage is their anything else i can check
Old 11-11-2007, 04:36 PM
Default RE: 03 trailblazer fan clutch
Can you be more specific as to the problem you are experiencing? Is the check engine light on? If it is, have you had the codes scanned (Autozone, Advanced Auto, and many other retailers do this for free).
Also, what brand of clutch did you install? Did you make sure that the electrical connection was fully seated? With the GMT360/370 platform, the operation of the fan clutch is PCM controlled and monitored. If the PCM senses anything wrong with the fan clutch, it will set a code and trigger the check engine light.
gitch93
07-23-2013 08:06 AM
cheesequaker
04-25-2012 01:44 PM
85kulan
10-04-2011 09:51 AM
MintyMadness
07-13-2011 12:37 AM
Red03
09-25-2008 08:37 PM
Quick Reply: 03 trailblazer fan clutch
