Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
4.3 Backflow and sound
Old Apr 12, 2025 | 11:51 AM
braden737's Avatar
I've had a dynomax 2.5" cat-back setup on my Sonoma for about 6 or 7 years now, and quite like it. It has a nice full sound at idle and driving around town, but no drone on the highway. Definitely don't expect a cammed V8 rumble, but it's a more full & deeper sound than the factory exhaust. Mine is only mildly louder than the factory exhaust.
As for any performance changes, the headers, cats, and the Y-pipe are the major restriction points in the exhaust, so unless you replace everything I wouldn't expect any major changes in any performance metric. Because those are all upstream from the muffler, the muffler and larger down-stream cat-back tubes won't change anything with the back-pressure.
As for MPG, I did not notice any change to my fuel economy with that mod.
Can you use the stock tail pipe with the dynomax muffler?
Old Apr 14, 2025 | 09:44 AM
El_Beautor's Avatar
You can do anything if you are decent with a welder. Lots of places where you could find size adapters to adapt the muffler output to the factory 1.75" pipes. The smaller pipe would likely result in a fairly quiet exhaust. Personally, I have a custom 2.75" pipe downstream from the muffler to the fender behind the rear passenger tire, similar to the routing of the factory exhaust.
iceblue068
Sep 9, 2016 03:51 PM
Draco2014
May 9, 2014 12:32 PM
96chevblazer
143
Mar 6, 2011 08:40 AM
Blazerx85
Feb 8, 2007 12:32 AM
kdanderson5
May 8, 2006 08:55 PM
