Another Dual Exhaust ?
I would like to put a Dual Exhaust System on my Blazer. However, I'm thinning of either sticking with the Factory Size Piping or going with Two and a Half Size Piping. My question is wich would be better or doesn't it really matter? I mean I'm not going for performance here just a nice sound.
Thank you.
Thank you.
if you go with a pipe size that is to big then you will run into a low back pressure problem and it will act funny, it will miss and eventually burn the valves because of a "too lean" condition as the O2 sensors will try to correct the running issue! I just went through this with my exhaust and it sucked until i figured out what it was. I would suggest 2.5" at the cat and if you do duals go with 2.25-2.5" do not use 3" anywhere in the system as it is too big and will cause faults to happen sooner or later
you do know you'll get a nicer, "deeper" sound from a quality single system, right?
if you're only looking for sound quality, then buy an aftermarket muffler (Flowmaster, Borla, Magna Flow). you can even get them with a single i, dual out option if you really want that dual "look".
------> keep in mind, a longer (ie: bigger) muffler will give you more of a baritone/bass pitch, resulting in a more mello sound.
if you are dead set on have "true" duals, then i'd stick with a max pipe diameter of 2.25", just to keep everything flowing as correctly as possible.
good point, never even took into consideration the whole inspection/etesting BS.
i'd like to see any Blazer run the dyno for the etest with duals. sure would be interesting.
