Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Another Dual Exhaust ?
Old Aug 24, 2010 | 04:19 PM
mrshaneb's Avatar
mrshaneb is on a distinguished road
Default Another Dual Exhaust ?
I would like to put a Dual Exhaust System on my Blazer. However, I'm thinning of either sticking with the Factory Size Piping or going with Two and a Half Size Piping. My question is wich would be better or doesn't it really matter? I mean I'm not going for performance here just a nice sound.
Thank you.
Old Aug 24, 2010 | 06:32 PM
rriddle3's Avatar
No difference to speak of in either category.
Old Aug 24, 2010 | 07:12 PM
Phil's Avatar
Just stick with a single catback system. Search this forum.
Old Sep 22, 2010 | 11:12 AM
88Vic's Avatar
88Vic is on a distinguished road
If you like how duals look, I would use 2" to 2.25" pipes, no larger so you keep exhaust velocity up.
Old Sep 22, 2010 | 11:40 AM
Benedict1337's Avatar
are you going to bend your own pipes or are you looking to get a cat back system?
Old Jan 2, 2011 | 11:45 AM
BadA$zBravada98's Avatar
BadA$zBravada98 is on a distinguished road
if you go with a pipe size that is to big then you will run into a low back pressure problem and it will act funny, it will miss and eventually burn the valves because of a "too lean" condition as the O2 sensors will try to correct the running issue! I just went through this with my exhaust and it sucked until i figured out what it was. I would suggest 2.5" at the cat and if you do duals go with 2.25-2.5" do not use 3" anywhere in the system as it is too big and will cause faults to happen sooner or later
Old Jan 2, 2011 | 02:23 PM
old skool luvr's Avatar
you do know you'll get a nicer, "deeper" sound from a quality single system, right?
if you're only looking for sound quality, then buy an aftermarket muffler (Flowmaster, Borla, Magna Flow). you can even get them with a single i, dual out option if you really want that dual "look".
------> keep in mind, a longer (ie: bigger) muffler will give you more of a baritone/bass pitch, resulting in a more mello sound.
if you are dead set on have "true" duals, then i'd stick with a max pipe diameter of 2.25", just to keep everything flowing as correctly as possible.
Old Jan 2, 2011 | 02:56 PM
true duals are impractical for the 4.3 especially if in your state you have inspections, because you will have to get another cat.
Old Jan 3, 2011 | 03:30 PM
good point, never even took into consideration the whole inspection/etesting BS.
i'd like to see any Blazer run the dyno for the etest with duals. sure would be interesting.
the_mind
26
Nov 26, 2008 12:45 AM
lucky03602
Sep 5, 2006 10:45 PM
Mylo_T_Cat
Mar 19, 2006 04:56 PM
blue_green_rider
Nov 17, 2005 07:11 PM
downhilryder
Oct 27, 2005 02:21 AM
