Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Couple Question
Old Jan 24, 2007 | 12:57 AM
TheDesertFox's Avatar
TheDesertFox is an unknown quantity at this point
Default Couple Question
Im sorry if these question have been answered before.
I plan in March on getting a Flowmaster 40 welded in place of the stock muffler. I just wanted to know if:
A) I plan on running new pipping from the cat-back, what diameter is the best?
B) I would love dual tailpipes running straight out the back, i know they wouldnt be true duals but can it be done without removing my spare tire (can they run the pipes around it)?
C) If in fact they cant run the tailpipes without removing the spare tire, i'd plan to put it on my roofrack, is there a spare tire bracket or holder that can attach to the roofrack to prevent the spare from sliding around on my roof?
-Thanks
-Luke
Old Jan 24, 2007 | 05:25 AM
KLBlazer07's Avatar
KLBlazer07 is an unknown quantity at this point
Default RE: Couple Question
There is the 2.25 and the 2.50.. might get a little bit more of a rumble with the 2.50.. but some shops can't make the 2.50 work on the Blazer so they go with the 2.25.
I was thinking about this as well, and after research and talking to some shops im pretty sure it can't be done properly without a lift on the truck.
You can always get those straps that hold it down, looks kinda ruggish too. Im sure if you look hard enough you can find something that will hold the tire.
Old Jan 25, 2007 | 12:38 AM
Thanks for the info, but i have infact seen a member's profile on here with his stock height blazer running dual tailpipes straight out the back. I wish i could remember his screename bit it escapes me now.
Couldn't they just run the tailpipe over the axle (like the stock tailpipe) and then split it off and run both pipes straight out the back, in theory?
-Luke
Old Jan 25, 2007 | 10:42 PM
KLBlazer07's Avatar
Did a little more research today for you while I was getting my exhaust done. It is possible to do duals, but you can not put it straight out the back so it looks centered. .. it has to be like the older novas where they are curved down or whatever else you choose.. you might be able to do it out the sides.. its cause of the gas tank being offcenter and a some other small things.. best thing to do is go talk to your shop and see what they say
Old Jan 26, 2007 | 12:29 AM
O ok, so not pointing straight out but have a downward angle at the end? ok thats cool enough, that'll be ok with me. thanks for your info!
-Luke
Old Jan 26, 2007 | 03:41 AM
KLBlazer07's Avatar
Yeah but thats just what he said and he showed me while it was up on the hoist. But it might be able to be done, just ask your shop.
Old Jan 26, 2007 | 01:54 PM
Yup, thanks a lot, either way sounds good. What are you getting done btw?
-Luke
-Luke
-Luke
DemoCar82
Nov 14, 2010 09:05 AM
Kilowat
Suspension Tech
Dec 19, 2008 07:25 PM
mmnj2603
Feb 8, 2006 06:30 PM
jschlip1990
Jan 26, 2006 07:22 PM
