Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Diameter piping?
Old Feb 2, 2006 | 05:40 PM
strongboy2005's Avatar
strongboy2005 is an unknown quantity at this point
Default RE: Diameter piping?
ORIGINAL: Hanr3
First off you cannot "gain hp" from an exhaust systtem. The hp comes from the engine, the exhaust system restricts the amount of hp the engine can create.
The simple answer to your question. 2 1/2" pipe.
The muffler with the best flow rate is a glasspack.
Most aftermarket performance mufflers have baffles that redirect the air flow to aquire a tone. They provide less restriction compared to a stock muffler, and thus increase your engines hp slightly, less then 5hp. A stock muffler runs the air through the muffler 3 times before it exits the muffler.
The best investment, if you really want to increase hp, is to get rid of the stock exhaust manifolds in favor of some headers. The exhaust manifold/headers, collector pipes, y-pipes is where you will have the most effect on your engiens performance. By time the exhaust gets back to your muffler, there isn't much difference you can make in freeing up engine hp.
The cat back system is designed for sound. Is that tone really worth $300.
So basically you are suggesting that for the best power to $$ value to skip the cat-back and go straight to an aftermarket header, collector pipe, and y-pipe?
You know of any companies that make these components for my application?
Old Feb 4, 2006 | 08:15 AM
Hanr3's Avatar
Try Headmann headers, and the others listed above, most make complete systems.
Old Feb 4, 2006 | 04:09 PM
ORIGINAL: Hanr3
They don't make them for 2003 Blazers
Old Feb 4, 2006 | 04:14 PM
ORIGINAL: 4lowlife
Depends what brand you prefer. CLick here for Pacesetter.
Pacesetter doesn't make anything for a 2003 Blazer
ORIGINAL: 4lowlife
CLick here for Gibson exhaust.
That exhaust system is for the 2 door ZR2 models only
Old Feb 4, 2006 | 10:14 PM
20Blazer00's Avatar
Here is a comparison pic I shoped together to show the differnce between the 2 models of gibson exhaust for the 2dr that you refer to. As you can see the ZR2 only version (Bottom) looks almost identical to the standard non zr2 (Middle) version. So I would consider sending them an e-mail asking them if the 4dr model (Top)shown will work for your 03...
[IMG]local://upfiles/1127/5EDBF648FC6247EF8252E8870174D32B.jpg[/IMG]
Old Feb 6, 2006 | 08:17 PM
cherryred4x4's Avatar
cherryred4x4 is an unknown quantity at this point
I have a Dynomax cat-back on my 95 that I got from summit racing. It is 2 1/2 inch piping, 2 1/2 is big enough for a Blazer, stock is 2 1/4 I believe. The only real thing i got out of it was 1-2 MPG and the sound, not much performance gain.
I looked on www.truckperformance.com and www.summitracing.com and didnt find any cat-back systems for your a non-ZR2 blazer. I agree with 20Blazer00 to check with Gibson and find out what the difference is between the kits....the ZR-2 may fit. You can also try searching google or another search engine for 2003 blazer performance exhaust.
As far as the headers, I think Edelbrock makes some, and heres a link to JBA headers for your 2003... JBA Headers
I wouldnt expect to pay less than $500 for headers, and then its pretty tight in the engine bay, so installing them will be a pain.
Old Feb 6, 2006 | 08:21 PM
Sorry, forgot to include about the muffler. I have a Dynomax Super Turbo muffler. It had CFM numbers on the box and they were higher than both Flowmaster 40 series and Gibson. Gives a pretty deep tone too, deeper than other Blazers i have heard, but its not too loud inside the cab like some exhausts, (doesnt drone).
Hope some of this helps.
Old Feb 7, 2006 | 05:40 AM
Thanks for the advice cherry
Old Feb 10, 2006 | 05:37 PM
strongboy 2005, check out the for sale section, timetoblaze has a jba catback listed for sale for $40+ shipping. for that price i would try it
Old Feb 10, 2006 | 05:42 PM
ORIGINAL: cherryred4x4
wow, nice, thanks for the heads up...
