Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Dual exhaust on a 4door blazer
Old Jul 25, 2007 | 10:02 PM
rriddle3's Avatar
Default RE: Dual exhaust on a 4door blazer
Honestly, I don't believe there is much merit to a dual system on a V6 like the Blazers have. The single line was designed by the factory to match the exhaust characteristics of the engine itself. Perhaps a hi-perf V6 would be able to utilize a true dual, but almost all 6's that you see with two tailpipes are just that - 2 tailpipes from the muffler. V6's have never sounded right to me with true duals because the exhaust pulse is completely different to that of a V8, that's why 8's sound good with them.
Old Jul 26, 2007 | 12:14 PM
RCars2's Avatar
RCars2 is an unknown quantity at this point
It is possible to do a catback dual exhaust setup kinda like how lastcoupe was suggesting. As a matter of fact thats pretty much what i got minus the larger y-pipe. I have a single inlet dual outlet flowmaster with pipes running back on the factory side and then they are bent to go out their proper sides. I had to take my spare out but when you do that you got options. You can put it on the roof (like i did for a while), you can get the mount inside the truck (works but not my preference), or you can get the tire carrier for the rear and start drillin (like i did). At any rate you wanted to know if it performs and sounds good. Performance wise i got a little more throttle responce and i picked up about 1-2 mpg. As for sound well listen_for_yourself.
Old Jul 26, 2007 | 02:36 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Thanks for the sound clip, it sounds good. I am not sure what I am going to do cause I think a single inlet/outlet would be easiest and cheapest. I called up LMC and they said it was for an S-10 pickup, but the guy didn't sound like he new anything and was just reading off a computer screen, so I am going to look for a pic of the underside of an s-10 and of the blazer and see if the exhaust and other areas match up. I don't think it will work but it worth another look.
-Lenny
Old Jul 26, 2007 | 03:39 PM
aced411's Avatar
aced411 is an unknown quantity at this point
A little while back the guy at my local exhaust shop told me on a 4.3 blazer the engine needs a certain amount of back pressure, and if I put in dual exhaust I would actually lose power. Just food for thought
Old Jul 26, 2007 | 03:49 PM
drperry's Avatar
You'd have to get smaller pipes to help keep the back pressure up
Old Jul 27, 2007 | 01:56 AM
Well, it doesn't look like it will fit so I am just going to do the Flowmaster, Hi-flow cat, and new piping option eventually. Don't want to hassle with finding another place for the spare and then possibly losing power and the extra cost of getting a dual outlet exhaust.
-Lenny
Old Jul 27, 2007 | 04:43 AM
drperry's Avatar
Get a dual outlet muffler, or a dual outlet tip...
That's what I'll probably end up doing
Old Jul 27, 2007 | 10:12 AM
eshballa5's Avatar
eshballa5 is an unknown quantity at this point
I have a single inlet/dual outlet VForce muffler. It sounds pretty good. I got it done for about $200 with a new muffler, new piping from the muffler back and 18" stainless steel tips. i think it sounds pretty good. especially for a V6. the system your looking at has no muffler and on a V6 it sounds a lot better with a muffler. straight piping a V6 isn't the best. at least from what ive heard.
Old Jul 27, 2007 | 04:16 PM
TheBrettster's Avatar
TheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond repute
ORIGINAL: rriddle3
Exactly plus the lack of backpressure.
Old Jul 27, 2007 | 04:29 PM
drperry's Avatar
I took the mufflers off my old Z34, and got better MPG and more power...
Granted I still had the cat in there, but still...
