Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Duals on stock height blazer 4x4
Old Oct 22, 2006 | 12:12 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default Duals on stock height blazer 4x4
Is it possible? Does anyone have pics of duals run on a stock height gen2 s10 blazer 4x4? I am looking to do this within the next month and I need some ideas. . I saw a guy once, run them under his axle... dumb as hell, I wouldnt do it. . . any other suggestions? It looks like it would be a very tight squeeze, and I dont necessarily have to have the pipes come out the back. . . I just need them to dump out somewhere behind the rear axle. . please help
I am wanting single inlet dual outlet... not true duals... OR can I get a replacement single inlet single outlet that will give me a sound like dual pipes... i've noticed that duals are a bit louder. . .
Old Oct 22, 2006 | 01:51 AM
mudsliner's Avatar
mudsliner is an unknown quantity at this point
Default RE: Duals on stock height blazer 4x4
i tried to run duals on mine didnt work the way i did it is it came out stock location on both sides but u have to go though the leaf springs eithe way you on the driver side and it hit the leaf sprign i i went with a single stright pipe and it sound better then dual stright pipes
Old Oct 22, 2006 | 02:32 AM
a_tack's Avatar
well, i was thinking of running the pipes side by side... i looked under the truck and there is alot of room right where the stock exhaust comes over the axle... i have no spare under my truck because it didnt come with one.... so i think im gonna bring dual pipes, side by side up and over the axle in the stock location and have them dump out just behind the axle, toward the ground... there will be no visible exhaust, because it will all be under the truck... and it will leave just enough room for a spare if i ever get one.... next step is ask the muffler shop how much it'll cost. .
Old Oct 22, 2006 | 03:08 PM
sledneck16's Avatar
sledneck16 is an unknown quantity at this point
anyone ever think of running them through the frame above the axles?
Old Oct 22, 2006 | 04:44 PM
mudsliner's Avatar
mine was above the axle but where i wanted them to come was not possible
vwgary
Tires and Wheels
Mar 4, 2008 06:43 PM
tekaz_s10_420
Tires and Wheels
Apr 21, 2007 03:12 PM
Kaffeene
Tires and Wheels
Mar 19, 2007 08:07 PM
DetroitMuscle
Suspension Tech
Oct 10, 2006 08:53 AM
