Dynomax 17366 Cat Back does NOT fit 2dr.
The Dynomax 17366 is a nice little cat back, in particular at $125 at Summit with a $75 rebate from Dynomax.
But, 2 Door owners beware, this system WILL NOT fit on a 2 Door Blazer. It is not as simple as shortening the tail pipe either.
The distance between the frame rails on the 2 Door narrows in the area of the muffler, where it is still running straight on a 4 Door.
Because of this, the muffler is too wide, and will be right against the passenger frame rail (within 1/4").
Also the tail pipe routing is different, the supplied pipe for the 4 Door runs over the axle and outside the rear shock, where the 2 Door pipe runs over the axle and inside the rear shock then crosses over.
Some web sites state that the system fits both 2 Door and 4 Door, and in details for the tail pipe only, it does not specify 2 Door or 4 Door.
I bought the system because it was the best value for me to replace the remainder of my exhaust system, and did not notice the differences until I had cut off the old system!
Fortunately, I have a shop where I fabricate turbocharger tubing, so I have the ability to cut/weld/modify.
So I am sectioning the tail pipe to get the correct routing, and the muffler had to be rotated slightly to give clearance at the frame rail. But I will make it fit, where the normal owner would have a huge problem trying to fit it on a 2 Door.
Odd that they do not make a system for the 2 Door.
Yes, I saw where Gibson lists an application for the 2 Door, but aluminized steel was close to $350, and stainless was close to $450. I am sure part of the issue is that on the 2 door, the tailpipe routing is tight, and it does not appear that one can be bent easily using a normal mandrel bender.
On my bender which is typical, it requires 4" minimum between the bend tangents on each bend. in several places on the tailpipe I hand fabricated yesterday, there were bends to close together to be made as a single piece of tubing on a bender.
Ther 4 door tailpipe had adequate distance between the bends.
The original tail pipe on the 2 door appears to be hydroformed which does not require the distance between the bends, but generally only OEM manufacturers have such equipment as it is very very expensive.
I know this is an old thread, but figured id try anyway. Do you have any pics of what you had to do to the axle pipe?
I just bought the kit for my girls 03 Xtreme, not realizing it was for 4 door only. I can cut, section and weld pipe if need be, but if it needs to be re-bent im screwed
BLK85
Headers, Intake, & Exhaust
Jan 14, 2008 01:47 PM
