Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Dynomax 17366 Cat Back does NOT fit 2dr.
Old Aug 29, 2010 | 10:45 AM
MrMopar+GM's Avatar
MrMopar+GM is on a distinguished road
Default Dynomax 17366 Cat Back does NOT fit 2dr.
The Dynomax 17366 is a nice little cat back, in particular at $125 at Summit with a $75 rebate from Dynomax.
But, 2 Door owners beware, this system WILL NOT fit on a 2 Door Blazer. It is not as simple as shortening the tail pipe either.
The distance between the frame rails on the 2 Door narrows in the area of the muffler, where it is still running straight on a 4 Door.
Because of this, the muffler is too wide, and will be right against the passenger frame rail (within 1/4").
Also the tail pipe routing is different, the supplied pipe for the 4 Door runs over the axle and outside the rear shock, where the 2 Door pipe runs over the axle and inside the rear shock then crosses over.
Some web sites state that the system fits both 2 Door and 4 Door, and in details for the tail pipe only, it does not specify 2 Door or 4 Door.
I bought the system because it was the best value for me to replace the remainder of my exhaust system, and did not notice the differences until I had cut off the old system!
Fortunately, I have a shop where I fabricate turbocharger tubing, so I have the ability to cut/weld/modify.
So I am sectioning the tail pipe to get the correct routing, and the muffler had to be rotated slightly to give clearance at the frame rail. But I will make it fit, where the normal owner would have a huge problem trying to fit it on a 2 Door.
Odd that they do not make a system for the 2 Door.
Old Aug 29, 2010 | 03:51 PM
DKSDAD's Avatar
I have yet to find a kit from any of the more performance oriented exhaust companies that show any love towards the 2 door's.
Old Aug 30, 2010 | 05:55 AM
nj4x4blaze's Avatar
Gibson makes exhaust systems for 2 door blazers.
Old Aug 30, 2010 | 06:35 AM
MrMopar+GM's Avatar
Yes, I saw where Gibson lists an application for the 2 Door, but aluminized steel was close to $350, and stainless was close to $450. I am sure part of the issue is that on the 2 door, the tailpipe routing is tight, and it does not appear that one can be bent easily using a normal mandrel bender.
On my bender which is typical, it requires 4" minimum between the bend tangents on each bend. in several places on the tailpipe I hand fabricated yesterday, there were bends to close together to be made as a single piece of tubing on a bender.
Ther 4 door tailpipe had adequate distance between the bends.
The original tail pipe on the 2 door appears to be hydroformed which does not require the distance between the bends, but generally only OEM manufacturers have such equipment as it is very very expensive.
Old Jun 24, 2011 | 07:46 PM
Interceptor9C1's Avatar
Interceptor9C1 is an unknown quantity at this point
I know this is an old thread, but figured id try anyway. Do you have any pics of what you had to do to the axle pipe?
I just bought the kit for my girls 03 Xtreme, not realizing it was for 4 door only. I can cut, section and weld pipe if need be, but if it needs to be re-bent im screwed
Old Jun 25, 2011 | 03:46 PM
MrMopar+GM's Avatar
I will see if I have pics, but I had to use a couple odd bends, section it to make it a two pipe section, use a torque tite clamp, and make a new hanger. Took some work for sure, I think I used like five bends to make it.
Karcinagin
Feb 22, 2011 01:10 AM
95LS
Aug 21, 2008 08:16 PM
95LS
Apr 13, 2008 12:24 AM
BLK85
Jan 14, 2008 01:47 PM
