Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
exaust tips
Old Sep 20, 2005 | 08:30 PM
BlaZeR FXB1581's Avatar
BlaZeR FXB1581 is an unknown quantity at this point
Default exaust tips
does anyone know if exaust tips actually make the exaust sound nicer or are they just for looks?....i am wondering cuz i want a quick fix for the exuast note till i can afford a full exaust system....any info would be appreciated
Old Sep 20, 2005 | 11:34 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
Default RE: exaust tips
they're just for looks unless you get one with a resonator in it. even that dosent do much, it just kinda smoothes out the tone.
Old Sep 21, 2005 | 07:47 AM
chevylane2003's Avatar
chevylane2003 is an unknown quantity at this point
It all depends on the tip. If it just slides over the end of the pipe and gets screwed on then it is probably just for looks. If you have to cut some of your pipe out to make it fit under your truck then chances are that it will change your tone to an extent.
(Take a look at some of the full sized trucks running around town. Many of them will have tips that are about a foot long and 2.5 to 3 inches round. Listen to the way they sound. If you like it just ask what they have for exhaust. Many will be just the tip with factory setup. Some may have removed there muffler all together. Just keep in mind that most of them are running V8's so anything smaller will likely have a higher and quieter tone.) Not much can be expected from a just a tip.
Changing the muffler on the other hand can make serious changes to the tone. Good or bad depends on the muffler and your taste. Most exhaust shops offer Flowmaster mufflers. Even a cheap one would change things up.
Old Sep 23, 2005 | 03:27 PM
Patrick's Avatar
Patrick has disabled reputation
it also depends on whre your exhaust ends, and how it ends, without the tips...for instance, if your actual pipe ends well under the truck, adding a functional tip that is, say, 3" around and 2 feet long, will give it a deeper sound...
Old Sep 24, 2005 | 05:53 AM
That may be but if you end it under the like I did mine then you will be able to here a lot of that exhaust noise on the inside as well. Make sure you can deal with that before you cut it off.
Stablock
Mar 27, 2007 12:11 AM
nofear17bmx
Feb 20, 2007 06:15 AM
nofear17bmx
Jan 27, 2007 01:49 AM
nofear17bmx
Nov 23, 2006 07:09 PM
offroadin00blazer
Sep 17, 2006 12:50 AM
