Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
gears
Old Oct 18, 2006 | 01:25 PM
DS01blazer's Avatar
DS01blazer is an unknown quantity at this point
Default gears
locking for 4 11 gears for my 01 blazer i cant find them and my gears are smashed AGAIM and last time that thay brock it wose 3000 and i would lick to just get some 4 11 and put them in my self. but i need help find them.
Old Oct 18, 2006 | 04:17 PM
tommyd's Avatar
tommyd is an unknown quantity at this point
Default RE: gears
i have no idea what you just said.
Old Oct 18, 2006 | 04:47 PM
EkStreem G's Avatar
EkStreem G is an unknown quantity at this point
Default RE: gears
Yea that was confusing, i'm pretty sure he's looking for 4.11 gears, how about 4.56 gears?
4.56 Gears For Sale
Old Oct 18, 2006 | 06:19 PM
Default RE: gears
I had started a thread in response to this, but just stopped... It seems that so many people just don't want to do the leg work any longer. Plus, they provide no information to help us out in helping them out. Sure, in this case, we know that it's an '01, but that's it... It would be nice to know if it's 2wd or 4wd cause that's a huge difference.
Old Oct 18, 2006 | 11:59 PM
DS01blazer's Avatar
Default RE: gears
sorey about that it is a 4dor it has 4wheeldriv. what hapend wose that i ran it without lobe in and it striped the gears and i herd that 4 11 would mack it faster if those rong then what do i ned? again sorey 4 all the confusion
Old Oct 19, 2006 | 10:01 AM
offroaddude77's Avatar
offroaddude77 is an unknown quantity at this point
Default RE: gears
wow it is realy hard to understand what you are saying. you need to like proof read or something before you hit the "OK" button.
"Sorry about that, it is a 4 door, it also has 4 wheel drive. What happened was that i ran it without lube in it, and it striped the gears, and i heard that a 4.11 gear SET would make it faster. If this is wrong, then what do i need? Again sorry for all the confusion."----is this what ur trying to say???? also i would recommend a 3.73 or a 3.42 gear set if you're going to change it. A 4.11 is too much gear.
Old Oct 19, 2006 | 04:22 PM
alamantia's Avatar
alamantia is an unknown quantity at this point
Default RE: gears
If it came with 3.42's and you go with a higher numerical gear like 3.73, 4.11, 4.56 it will give you more pulling power but make your engine run faster on the highway. If you switch the gears in the rear from 3.42 to say 4.11 you will have to do the same with the front differential or the 4WD will bind when you use it. I suggest you find 3.42's to put back in it so that you dont have to spend money doing the front also. If it is an S-10 blazer its a 7.625 carrier (most likely a 3-series) these same gear sets can be found in 1982 through 2002 camaros and firebirds. A lot of people take them out of the camaros and firebirds and install 3.73's and 4.11's this is why you can find used sets of 3.42 gears all over ebay and the internet for sale reall cheap. I have a few sets out of my SS and Z28 myself. If you have never done a gear swap before I dont suggest doing it, you need special tools as well such as a dial indicator not to mention plenty of shims, a press etc. If it is a full size blazer Yukon, Tahoe, K1500 etc. you can not use camaro and firebird gears. You need to find Blazer, suburban or Pickup gears that fit your full size blazer. Good luck
Old Oct 23, 2006 | 02:52 AM
DS01blazer's Avatar
Default RE: gears
thanks
James1965
Jan 16, 2012 11:32 AM
5.7Lblazer
Street N Strip
Mar 15, 2007 10:52 PM
76BadSign442
Feb 4, 2007 08:56 PM
97blz4x4
Jan 22, 2007 04:16 PM
timetoblaze
Sep 25, 2004 01:11 PM
