Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
looking fo more horse power
Old Feb 9, 2010 | 07:12 PM
  #21
Call around to a few of the major cam companies. Most of them have exceptional tech lines. But I warn you, you have to have realistic expectations and know what you want to get out of it in the end. Just saying "as much hp as I can" is not going to cut it. Where do you want the power? What do you want to accomplish with said power? etc.etc.etc.
Old Feb 9, 2010 | 07:15 PM
  #22
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
i know a guy that had "too" big of a cam as in hp and he runs nothing but premium. his is a bronco and he's got problems with knock on lower octane. don't know if you'll run into that with these blazer since they have knock sensors but i thought it be something worth mentioning.
Old Feb 9, 2010 | 07:20 PM
  #23
kevin turner's Avatar
kevin turner is on a distinguished road
yeah, thanks. I already run premium in mine i just want a little bit biger with a ran form 0-5000 it is a daily driver so i dont want that ruff idle. just a little more toruqe
Old Feb 9, 2010 | 07:21 PM
  #24
Originally Posted by kevin turner
I also found this and its way i done the mod on the tb http://marine-performance-parts.com/...lv6vortec.aspx
Basically the same thing you did, but costs $$$. Still has the same result. Increased throttle sensitivity at lower throttle angles, but no impact on WOT performance. I did scanned tests with and without the deflector and times to 60 didn't budge with the modded throttle blade.
Old Feb 9, 2010 | 07:26 PM
  #25
oktain's Avatar
I'm sorta hijacking here... so then the throttle blade off the 350's wouldn't be to my benefit if I were to do that swap? I remember reading somewhere (on here) that the 350's were a little shorter (the diverter flange)... So I'm guessing there's no point in running to the pick-n-pull to get one? Just a waste of 5 bucks?
Old Feb 9, 2010 | 07:35 PM
  #26
If you change the cam out for one that peaks higher in the RPM range, increasing the airflow needs of the engine, having a lower deflector on the throttle blade may provide further gains while still dispersing the EGR gasses properly in the intake.
Old Feb 9, 2010 | 07:36 PM
  #27
When i frist done the mods i feelet more power but know I think that the maf sensor has went hay wire like his done so im going to buy the aftermarket one that will slove the issue. I will try the sensor and post on it says 10-15 horse so that should be power i can feel.
Old Feb 9, 2010 | 07:38 PM
  #28
Banned
dyno is the true test
Old Feb 9, 2010 | 07:39 PM
  #29
so how big should i go on the cam? I want more power but still be reliable, ranging form 0-5500
Old Feb 9, 2010 | 07:51 PM
  #30
wlorton's Avatar
I think the best idea is to do a vortec 5.3 swap....
But if you google hotrod 4.3 they rebuild a 262 (4.3) to a 270 with a larger cam and all the info... they made a "reliable" 301hp...
