Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Realistic Expectations
Old Aug 11, 2011 | 07:01 PM
lo.1987's Avatar
lo.1987 is on a distinguished road
Default Realistic Expectations
Realistically, what can I expect as far as MPG and HP is concerned when it comes to adding an aftermarket muffler?
Old Aug 11, 2011 | 09:30 PM
Rottidog's Avatar
Not mucking fuch... maybe a teeny bit of power & mileage. Mostly sound, possibly throttle response because it may be breathing a bit better.
Old Sep 5, 2011 | 05:52 PM
4goodbuys2's Avatar
4goodbuys2 is on a distinguished road
You will defiantly get more attention from the cops.
I get around or under 1 mpg with a cold air intake I ended up taking it off and going back to the stock box.
I'm thinking about cutting a hole in the bottom of the box and adding piping down by the bumper.
Old Sep 5, 2011 | 08:06 PM
chris015's Avatar
I added a glasspack with cat delete. Noticed a SMALL difference in mid range speed (say if your at bottom of 3rd gear then you punch it). and throttle response was a little better. Other then that,meh its ok.
If you have a tbi system,best bang for the .25 cents is the quarter mod (stick a quarter on top of the spring in the fuel regulator) and grind down the ridges around the injectors. then advance your timing 2-4 degree's. I really noticed a difference after that and running 89 octane.
Old Sep 5, 2011 | 09:13 PM
Rottidog's Avatar
Remember that these engines require a certain amount of back pressure unless you get the PCM tuned to adjust for a more open/free'r (<--- is that a word?) flowing exhaust.
Google says no, it's free flowing - cest la vie
Old Sep 5, 2011 | 09:40 PM
wlorton's Avatar
Headers is the edge of a sword..... One slip and you go into the I like the sound, vroom vroom vroom and lose mileage. But on the other side you can drive it normal and maybe see about 1-3 mpg increase....
wlorton
Aug 24, 2010 01:12 PM
Biohazed
Oct 25, 2009 10:54 AM
step66
Nov 21, 2008 04:16 PM
strongboy2005
Feb 10, 2006 04:22 AM
