Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Some exaust questions
Old Nov 21, 2006 | 02:10 PM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
Default Some exaust questions
I am planing on putting an exaust on my 2000 chevy blazer 4dr 4x4. I am pretty sure I am going with the Super 40 Series since it gives the rumble sound I am looking for. I have a few questions though:
1. What is the in and out size of my stock system so I can find the right size muffler to buy.
2. Should I just buy the Super 40 Series muffler like on ebay, or should I get all the piping also?
3. I see that some people run 1 single pipe into the muffler and dual out, wont this not create enough back pressue for the engine and make it run different?
Old Nov 21, 2006 | 05:22 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: Some exaust questions
1. 2.25" offset inlet/center outlet..........
2. just buy it at the muffler shop, it'll be about the same price......
3. you can't run duals on a 2000 4x4 without lifting it or removing reese hitch and spare tire....duals just aren't in the cards for stock height...
Old Nov 23, 2006 | 04:31 PM
20Blazer00's Avatar
ORIGINAL: nofear17bmx
If you do a cat-back system there is no problem with back pressure since it is the diameter of the exhaust manifold/downpipe/catylitic converter that will determine backpressure in an exhaust system. You should be fine but I would upgrage the piping to a min. of 2.5" mandrel bend or 3" pressure bend pipes. The only real area that will cause a problem with your method is the area of pipe behind the muffler that goes "up-n-over" the rear axle, most of the other piping in front of the muffler and behind the converter can be pressure bends since they are not that drastic.
Old Nov 23, 2006 | 06:57 PM
I took a look at the muffler today and saw that the stock muffler is at least 3 feet long if not more. From the pictures the Flowmaster Super 40 Series is only like a foot and a half. So what do I have to do to take up the space that will be missing?
Old Nov 23, 2006 | 07:07 PM
Just get a piece of exhaust tubing when you buy your muffler. Get atleast a 2' piece and cut to fit once you have the stock muffler out.
Old Nov 23, 2006 | 07:09 PM
Should I get adaptors and stuff since the same size tubing wont just slide together.
Survivor
Apr 22, 2009 11:31 PM
nofear17bmx
Feb 20, 2007 06:15 AM
nofear17bmx
Jan 27, 2007 01:49 AM
offroadin00blazer
Sep 17, 2006 12:50 AM
BlaZeR FXB1581
Sep 24, 2005 05:53 AM
