1.5" Shackle Dimensions(PLZ HELP!)
hello, yes i know there a couple fourms out there about this, but it has known of my answers.
i believe that it is 9" Long and 7" Hole to Hole i Believe... PLEASE HELP |
Yes 7" will do it.
what part of Van Isl do u live on? |
Originally Posted by c1rca121
(Post 383057)
thanks man, do you no the inside width? i think it is 3" but im not sure
okay now what is the hole size? i read on blazin Jason it is 9/16 but there was another fourm sayin something else (btw its A 97 blazer)
We did our last set 9/16. So that should work as well
okay thanks guys, i no you can use the stock nut and bolts but im getting new ones, i talked to GM they say the bolt length is 4 1/8" .. now is that correct?
Thanks Very Much |
I'm not sure on the size. Inside shackle width will be 3" plus the thickness of your shackle material. Then allow enough extra thread for the nut to fully thread on.
Ok i Built Them Thanks For Your Help :)
Heres some pictures http://i580.photobucket.com/albums/s...1/DSC00286.jpg http://i580.photobucket.com/albums/s...1/DSC00285.jpg http://i580.photobucket.com/albums/s...1/DSC00282.jpg http://i580.photobucket.com/albums/s...1/DSC00281.jpg |
Outside welds look OK but the inside ones look cold, some undercut & not welded at the right angle. I'll guess you welded the inside 1st?
Sorry but being a welder for 18 years, lead hand & always looking at QA (Quality Assurance) does this to me. lol I'd think about trying to grind off some of that hump on the inner welds & rewelding them, for safety sake at least & then you can get rid of the spatter as well. Looking good & should look great with a coat of paint or powder coating! |
thanks Rottidog, i welded the outside first... it was a really old welder, it wasn't working properly. haha im only 16 so i think that's some pretty good welding :P ill probably be painting them black... they should be strong enough, Ive seen the the shackles that autozone sells and there isn't any bracing all it is 2 pieces of metal, it is kind of funny. i will have them installed pretty quick here
Looks good :) saves a bunch of money over buying a set, and they are much stronger then those cheap universal ones people keep recommending.
