1 inch body lift?
Old Mar 31, 2010 | 06:51 PM
88s10Blazer's Avatar
88s10Blazer is an unknown quantity at this point
Default 1 inch body lift?
I just want to do T-bar crank and shackles and want to fit 31's but don't want to do any trimming. Could I just get a 2 inch lift and cut the blocks down to 1'' and get some shorter bolts? I don't want to do the whole 2'' because I really don't like the looks of a body lift, but I think I could live with just 1''. Thanks. Mitch
Old Apr 1, 2010 | 06:33 AM
nj4x4blaze's Avatar
1" body lift? Why even bother installing it. lol... Whether it's a 1" bodylift or 2" bodylift you are going to see the frame anyway so you might as well stick with the 2" BL.
Old Apr 1, 2010 | 10:22 AM
I just want a little bit of clearance for the bigger tires without the whole 2''. You really didn't answer my question btw
Old Apr 1, 2010 | 10:59 AM
sifd4x4's Avatar
sifd4x4 is on a distinguished road
what tires are you looking at?
cause it seems that certain brands of 31's will fit without trimming and just the crank and shackles as long as the tire is not too aggressive.
Old Apr 1, 2010 | 11:37 AM
dougg01's Avatar
dougg01 is on a distinguished road
I understand what you are wanting to do. I'm looking to do a 2" BL now that I have my 31x10.50-15 Firestone ATs on my Jimmy and needed to trim (only the inside of the wheelwell) and a little hammer time. I don't like how much frame shows on a 2", but could live with it. I dont' really need 2" though. 1" would get mine room to spare.
I guess if you could source repalcement bolts that are 1" or so longer, get new biscuits (bushings) and fab some spacers you could get it done with a minimum of fuss.
Tell you what I won't do.....I won't buy a new 2" kit and cut it down to 1". If I buy a new 2" kit....the truck is getting 2" and I'll get someone to fab some sliders to make the frame look less LARGE under the body. With 2" BL and the right offset wheels you can run 32" or 33" tires.
Old Apr 1, 2010 | 11:43 AM
I was thinking the Cooper Discovery STT in 31x10.5x15. With an after market set of rims with 4'' backspacing.
http://www.offroaders.com/tech/AT-MT...overer-stt.htm
Old Apr 1, 2010 | 02:09 PM
nj4x4blaze's Avatar
If all you are looking for is a yes or no answer, then yes. If you really want to modify the pucks you can and just get the same bolt but just shorter. Before you modify the body lift, test fit the wheels on your truck since you will have 2" shackles and cranking the tbars 1.5". Maybe you wont need the body lift.
Old Apr 1, 2010 | 04:07 PM
Thanks. The actual diameter of the tires are 30.75. Any ideas about the bumper bracket?
Old Apr 3, 2010 | 05:21 PM
nj4x4blaze's Avatar
The bumper brackets could cause an issue since they are designed for the 2" bl, so you might need to make your own brackets or try to see if your bumper will bolt up to the stock location.
Old Apr 3, 2010 | 08:29 PM
I'm going to call PA Monday to see if they could maybe help me out with anything. Thanks for the replies. I've installed body lifts before, but not with the bumper brackets.
Keeler
Lifting Tech
22
May 29, 2010 03:53 AM
blazinUP
Tires and Wheels
May 14, 2010 08:06 PM
K5-Roots
Lifting Tech
Feb 6, 2010 12:09 PM
brino1
Dec 16, 2009 04:17 PM
