2" body or 2" suspension lift?
I want to run 31x10.5's and know that I need to come up 2" from somewhere. The body lift seems like more of a pain in the ass than the suspension lift, but I hear the suspension lift is hell on CV's and ball joints. So whats a man to do?
RE: 2" body or 2" suspension lift?
I would just go with a body lift, but if your the lazy type then go with the suspension shackles and tbar crank, it wears down ball joints and cv's though.
there are susp kits that offer drop brackets to keep OE cv angles
If you wanna spend $2k.
The 2' kits give you new upper control arms to correct the balljoint angles...but you're still risking the CVs. |
Do the BL, much cheaper, doens't mess with suspension angles, easy to install. Just takes some of your time to install.
I am personally going with a suspension lift and why not do both? Thats my plans untill I can do a SFA swap
Marcus in Nebraska |
ORIGINAL: mpaczosa23 I am personally going with a suspension lift and why not do both? Thats my plans untill I can do a SFA swap Marcus in Nebraska |
other than greater wheel/tire clearance, and appearance, what does a body lift give you? it doesn't improve clearance, does it?
what does the equipment/price list look like for a moderate (1.5"-2") suspension lift, done properly, minimizing risk to ball joints & etc.? |
A body lift really only serves to increase your approach and departure angles. The rockers are a bit higher in relation to the tires so theres a better angle there...but no other clearance gain. The frame rails stay put.
For a 1.5-2' suspension lift, you need 2' lift shackles for the back (or you can go the add a leaf route). Then just a tube of grease to keep the front end lubed. I suppose a rachet socket wrench would help with the tbar crank.. |
ORIGINAL: WolfPack For a 1.5-2' suspension lift, you need 2' lift shackles for the back (or you can go the add a leaf route). Then just a tube of grease to keep the front end lubed. I suppose a rachet socket wrench would help with the tbar crank.. And, at what point are longer shocks necessary? Also, with 2" lift, is it going to look ridiculous with stock wheels and winter rubber? |
| All times are GMT -5. The time now is 10:27 PM. |
