2 in. bl with 33's?
Old Oct 17, 2008 | 11:11 PM
ncmudblazer's Avatar
ncmudblazer is an unknown quantity at this point
Default 2 in. bl with 33's?
i got a 97 blazer and i am going to get a 2 inch body lift for it. will i need an additional inch or two to clear 33's or will a good wheel well shave do?
Old Oct 17, 2008 | 11:20 PM
Millertime21's Avatar
Millertime21 is an unknown quantity at this point
Default RE: 2 in. bl with 33's?
I would guess you would still need shackles and a t-bar crank. I'm running 32" with a 2" BL and 1.5" shackles/t-bar and I still had to trim.
Old Oct 18, 2008 | 01:42 AM
WolfPack's Avatar
ZR2s have to trim a whollle lot to clear 33x12.50s with a 2' body lift...and they start out with 31s....we start a size or two down from the ZR2s...yea..
Old Oct 18, 2008 | 07:46 PM
myol blue4x4's Avatar
myol blue4x4 is an unknown quantity at this point
Well... you can fit 33's with just a body lift, the only problem is that you will only be going in a straight line. So you will have to go with a 2inch BL as well as tbar crank with shackles plus a lot of trimming. Not to mention you will have to upgrade to atleast 4.10 gears.
Old Oct 19, 2008 | 02:09 AM
vin791's Avatar
vin791 is an unknown quantity at this point
just get a 2" upper a arm lift plus tbar crank and 3" shackles and you should be ok. keep in mind though that at full lock anything bigger than 32x10s or so will rub frame at full lock.
Old Oct 19, 2008 | 12:18 PM
ORIGINAL: vin791
Ive never heard of an upper a arm lift, but the max total of lift without buying a 5-6 inch lift would be 4 inches total, 2 from the body lift and the other 2 from cranking the tbars, and getting 2 in shackles. You can get 3inch shackles and add-a-leafs but you have IFS, independent front suspention, so without a bought lift kit you can only get 2inches of lift. And as for tires, my 31's by 9.5's rub at full lock, so its safe to say anything pretty much over than stock has a chance of rubbing.
Old Oct 27, 2008 | 04:02 PM
thanks guys. oh and on the tbar crank my buddy mentioned that a might need keys for this. or can i just used a wench to lift it?
