2" body lift + 2" shackle lift SHOCKS?
Old 02-20-2010 | 04:51 PM
whitejimmy's Avatar
whitejimmy is on a distinguished road
Default 2" body lift + 2" shackle lift SHOCKS?
I have searched all through the threads and found many things on 2" lifts. Just couldn't find an exact answer to my question.
I know there are some on here that have a 2" body lift and a 2" shackle lift with T-Bar crank. My question is will I have to change the shocks if I do a 2" body lift and a 2" shackle lift? I hate to buy new shocks and then when I want to lift it have to buy new again. I have a 1996 GMC Jimmy 4 door 4x4. Any advice would be great thanks.
Old 02-20-2010 | 05:58 PM
Green Blur's Avatar
Green Blur is on a distinguished road
No, you don't have to change shock's. I have this done to my 96 2dr and did not have to change them.
Old 02-20-2010 | 06:14 PM
Benedict1337's Avatar
no you won't have to because a body lift doesn't affect the shocks. and the shackles and tbar isn't that much higher. I upgraded my shocks. I have rough country 2-6 inch lift shocks it flexes more since my shocks won't bottom out as easy
Old 02-20-2010 | 10:24 PM
whitejimmy's Avatar
Ok. Thanks guys. that's what I thought but wasn't 100% sure.
Old 02-23-2010 | 01:30 AM
whitejimmy's Avatar
Green Blur How much total lift did you gain with this kind of lift? Have you had any ball joint or cv joint problems with it?
Old 02-23-2010 | 02:46 AM
RebelJimmy96's Avatar
RebelJimmy96 is on a distinguished road
i still would get some offroad grade shocks like some rancho rs-5000's or bilstines
Old 02-23-2010 | 09:04 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
You don't HAVE to change your shocks. However, it would be a good idea. Rancho makes a nice 1-2" lift shock that would do the job.
Old 02-26-2010 | 08:26 PM
jimmy979's Avatar
jimmy979 is on a distinguished road
Lift shocks.. do they lift the front 2 inches..
Old 02-26-2010 | 09:12 PM
Blazers.B.Kewl's Avatar
Blazers.B.Kewl is an unknown quantity at this point
I think they mean lift shocks as in shocks for a lifted vehicle. A longer shock basically. And no, they wouldn't lift your front end. You have no shocks in the front! haha, You have torsion bars, thus the tbar crank
Old 02-26-2010 | 09:32 PM
ImScrewed92's Avatar
No shocks in the front? Really... You mean springs? The main reason most people get longer shocks with bigger tires isn't because of the factory being too short. Rather get them if you offroad really strong. Cause if you drop off a step, and the heavier tires can overextend (right term?) the shock and stress it. But I've got a 1 1/2 inch add a leaf, 3 inch body lift and about 1 1/2 t bar crank and in daily driving, the factory replacement shocks from Advance have been fine.
Last edited by ImScrewed92; 02-26-2010 at 09:33 PM. Reason: change body leaf to body lift :D
Quick Reply: 2" body lift + 2" shackle lift SHOCKS?
