2000 4-dr Blazer lift
Old Jan 14, 2014 | 05:12 PM
Trittboy's Avatar
Trittboy is on a distinguished road
Default 2000 4-dr Blazer lift
I definitely want to lift my 2000 chevy blazer to make it look and drive more aggressive. I was advised not to do this because it'll mess up all the steering components... Any suggestions?
Old Jan 14, 2014 | 06:19 PM
rexmburns's Avatar
Super Moderator
Read the other threads in this forum!
Old Jan 14, 2014 | 06:35 PM
warthogdriver's Avatar
Body lift no.
Cranking the torsion bars...maybe..depends on if you go crazy.
Suspension lift....i would advise upgrading beyond oem joints if running large tires.
But in the end there is alot of reading around here to help fill in the gaps and reasons.
Old Mar 17, 2014 | 09:14 PM
okiedoak20's Avatar
How much $$$ do you have....5-6" cost around $2200
Shackle and torsion bars crank about $70 ish....
Body lift (2") $200 .... I chose all the above...plus 33"tires
And want more...not to pee on anyones parade.. but if looks are what
You after, consider a body lift...you keep the same suspention
Stuff and nothing wears out, will beable to install 30-31"
Tires..
Old Mar 18, 2014 | 12:42 AM
LeWhite's Avatar
Buy a K5 they were made to lift not an s10.' Look more aggressive' is your opinion, and you are entitled to that. Drive more aggressive? It will prolly drive worse.
SmoyMoose
Mar 30, 2010 07:41 AM
SmoyMoose
Lifting Tech
Mar 11, 2010 09:57 PM
RIOT_707
Lifting Tech
18
Jan 23, 2009 06:53 PM
COUNTRYBOY061488
Aug 28, 2008 07:54 PM
jessesjimmy
Suspension Tech
Jan 27, 2007 01:20 AM
