2wd front
Old Jul 12, 2008 | 07:58 PM
fla_blazer4x4's Avatar
fla_blazer4x4 is an unknown quantity at this point
Default 2wd front
what is the cheapest way to lift a 2wd 2nd gen blazer 2.5-3 inches. in the front? i use to know where it was at but i did a seach and cant find the post
Old Jul 12, 2008 | 09:08 PM
myol blue4x4's Avatar
myol blue4x4 is an unknown quantity at this point
Default RE: 2wd front
I think you would have to settle with lift spindles, check on ebay im sure they have them.
Old Jul 12, 2008 | 11:42 PM
WolfPack's Avatar
Lift spindles would probably be cheapest. Other than that you're looking at new coils up front or cheaper coil spacers..but spacers alone won't give you the lift you're looking for I don't think..
Old Jul 13, 2008 | 12:47 PM
Just out of curiosity, what is the point of lifting a 2wd other than looks? Because if I was to go offroading in a 2wd lifted, I would try and barrel through deeper mud and just get stuck.[:'(]
Old Jul 13, 2008 | 08:03 PM
WolfPack's Avatar
4x4 won't help you in mud You need beefy lockers to be any good at deep mud
Notice the non-muddy rear wheel with traction... it just wasn't spinning because the other side was bogged in mud too.
Old Jul 14, 2008 | 02:15 AM
im paying 290 a month in insurance with a 4 wheel drive its going to be more money. i just got to do with what i got plus i cant get a 4wd since i just got my firt blazer, but just wondering if i do 3 inchesin backand 2 inches in front would that be noticable and i dont think i can add shackles becouse of my hitch seems to be a tight fit.
Old Jul 14, 2008 | 06:08 AM
jimmyboy's Avatar
jimmyboy is an unknown quantity at this point
you want the other way around 3in in the front and 2in in the back to make it look level. the other way the back would be higher then the front would.
jimmyboy
aka silveradoboy
Old Jul 14, 2008 | 10:36 AM
how would that be tho? wouldint i do 3 inch lift spindles and 3 in shackles that would make it level right?
Old Jul 14, 2008 | 11:15 AM
jimmyboy's Avatar
you could do 3in spindles in the front with 2in shackles in the rear.
here are some http://www.rockymountainsusp.com/GM_S10_2wd.htm
and then do some synergy offroad or 3 leaf fab shackles in the rear
i know you have a 05 blazer but im not sure what the suspension difference is between a 03 s10 but here is a 3in/0in lift thats for a s10 http://www.doetsch-shocks.com/14.asp
if you scoll down alittle bit on this link you can see some pics of some 2wd lifted s10s that have the name of the lifts under them http://www.rockymountainsusp.com/gal...evySSeries.htm
jimmyboy
aka silveradoboy
Old Jul 14, 2008 | 11:22 AM
thats what i been looking at is the3 inch 3 leaf fab shackles or the 2 but if i do that how much would i have to lift front to make even i dont want to spend money on 3 inch shackles and only can get 1 inch lift in the front and be all even i thought the rear sits lower then front couse of hitch weight and sag
