2wd suspension lift
Old Dec 6, 2010 | 10:40 PM
blazerpower's Avatar
blazerpower is on a distinguished road
i have a 96 s10 blazer 2wd and wanted to know what would be the best option for a suspension lift. i saw that rough country has a 2inch suspension lift and fabtech has a 3inch suspension lift but that one uses spindles and you cant just put bigger tires on the factory rims. has anyone else seen anything that would work or have any experience with the mentions kits?
dont know if it makes a difference but its a 2 door
Last edited by swartlkk; Dec 15, 2010 at 12:14 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member yet to respond.
Old Dec 7, 2010 | 10:12 AM
Red 96''s Avatar
The 2wd Blazers are lifted using spindles, and the biggest tire you can put on the factory rim is a 30x9.5x15 unless you lift it. With a 2" or 3" lift, you should be able to fit 31's with no issues.
Old Dec 7, 2010 | 11:36 PM
red how did you know i was thinking 31's
the rough country kit looked like it used longer coil springs
Last edited by swartlkk; Dec 8, 2010 at 09:57 AM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member yet to respond.
Old Dec 10, 2010 | 09:42 PM
so no love for the lifting a 2wd
Old Dec 11, 2010 | 10:02 AM
speterson1011's Avatar
speterson1011 is an unknown quantity at this point
You can get lift coils. The only problem is you have to get new upper a frames so they extend out farther so you can get it aligned. Also the lift coils will give you a really bouncy/rough ride. I used to have in 3'' lift coils. Very stiff ride. Now you buy the rubber coil spacers that look like big donuts and put them on top and bottom of your coil and it will give you a solid 2'' lift. I did this for a while and it provided a much smoother ride and was aligned when I took all the shims out.
Old Dec 11, 2010 | 09:24 PM
why wont the stock ones work?
Old Dec 11, 2010 | 09:48 PM
Well they will but your tires will be at a weird angle and you cannot get them aligned and they will wear down very fast. It will cause you to have a negative camber is what I'm getting at. And there is no way to fix it unless you get tubular upper a frames that go out wider offsetting this.
Old Dec 11, 2010 | 10:02 PM
where could i find those at
Old Dec 11, 2010 | 10:22 PM
I've heard moog makes some I would look into that first. But you could by a frames from the 2wd s10 lifts. They are exactly the same. My whole lift is from an s10. Mine are fabtech but I think rough country makes some too
Old Dec 12, 2010 | 07:55 PM
http://www.moog-suspension-parts.com...rod=MOOG-K6218
is that what you are talking about? or do they actually have A-arms ?
