2wd suspension lift
Old Dec 14, 2010 | 07:45 PM
rocpede4x4's Avatar
rocpede4x4 is on a distinguished road
i say get some 3" lift spindals and a 2" body lift then put some 31" tires
Old Dec 14, 2010 | 11:09 PM
Blazerkid01's Avatar
Blazerkid01 is on a distinguished road
Default Wat bout 4x4
What about rough country's 2in 4x4 lift and a 1.5in body lift on a 1991 4 door s10 blazer? would i need to make any modifications to the steering column or the tranny linkage? Could i run 32s?
Thanks Blazerkid01
Old Dec 15, 2010 | 12:00 PM
nismo_2005's Avatar
nismo_2005 is on a distinguished road
speterson do you mean a arms? i had 2" lift coils and got my old 2wd aligned perfect. if i was you i would go with 2" dick cepeck coils 3" aim spindles (the fabtech ones are way more expensive) run shackles in the back and through on some 31's that is the same setup my old 2wd rcsb dime had. but if im not mistaken you may have to swap out your front brakes for s10 brakes to make the spindles fit.
here are the spinldes
http://cgi.ebay.com/ebaymotors/S10-S...ht_4566wt_1167
this is a short arm kit. i belive it is what speterson was talking about it has new upper control arms to correct alignment. it also comes with everything you need to do the whole lift.
http://cgi.ebay.com/ebaymotors/CHEVY...ht_4240wt_1167
aim also sells kits with 3" springs for the short arm kits. and i have heard that as long as you have upper a arms you can run a 3" spring
Last edited by swartlkk; Dec 15, 2010 at 12:14 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member yet to respond.
Old Dec 17, 2010 | 12:48 AM
blazerpower's Avatar
blazerpower is on a distinguished road
so that would give me 5 inches of lift? what is a flip kit? and is there an actual store i can go on their website or is it only ebay stores?
Old Dec 24, 2010 | 08:32 PM
any other ideas
Old Jan 12, 2011 | 07:11 AM
is there anything else that can be done with 2wd
Old Jan 14, 2011 | 02:57 PM
ScottyBoy98's Avatar
ScottyBoy98 is on a distinguished road
a flip kit is when you weld a perch on your rear axle then mount your leaf springs on top of it, instead of being hung under your axle...so it gives you about 4 to 5 inches of lift (leaf spring pack + axle diameter + perch height)...so to match it up front you'd need the 3 inch lift spindles and some 2 inch coils - then 31's would be no problem at all
Old Jan 23, 2011 | 11:49 AM
speterson1011's Avatar
speterson1011 is an unknown quantity at this point
2INCH lift coils can be aligned. My 3inch lift coils with stock a frames will not work. Those offset uppercontrol shafts are the way to fix it. Even with tubular a arms they were not even close to being aligned. Flip kit is the way to go in the back. I did that and put a 2inch block in and cleared 35''s easy. So my 33''s now have plenty of room to flex. 2WD theres not much lifting you can do in the front without doing a lot of fabrication. Basically coil spacers or lift coils and spindles is really all you can do.
If you do a axle flip kit be sure to weld the perch that the block or leaf spring sits on ontop of your axle. Some people just u bolt them tight but if your doing any offroading it's possible for the axle to twist forward or backwards and snap your driveshaft. It happened to a buddy of mine and it was no fun. So I made sure I arched welded mine on the axle and then ubolted them tight
wlorton
Lifting Tech
16
Dec 26, 2009 05:05 PM
<3blazer
Suspension Tech
Jun 13, 2009 09:32 PM
Tippman7641
Apr 6, 2008 07:20 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
