3 in lift
Old Sep 16, 2009 | 05:17 PM
classklown90's Avatar
classklown90 is on a distinguished road
Default 3 in lift
I have a 94 blazer and am looking to get a 3in lift on it and myabe 31's. My question is simply how hard would this be for two people to do? and also will 31 in tires on 15x8 rims fit on this without rubbing?
Old Sep 16, 2009 | 11:19 PM
realestkilla420's Avatar
realestkilla420 is on a distinguished road
31s will fit on it without the lift but they will bind slightly easy fix thought go to advance and buy a shackle kit install it on the back and then tighten up the torsion bars and then go get it alighned 1 person can do that and it will cost u around 75 bucks hope that helps you might be able to get 3 inches outa the torsion bar trick and the shackles will give u 3 inches
Old Sep 18, 2009 | 06:19 PM
ok cool thanks
Old Sep 20, 2009 | 12:07 AM
neo71665's Avatar
You DO NOT wanna try to jack the torsion bars over 1 1/2 inches unless you like replacing front CV joints and ball joints.
Old Sep 20, 2009 | 12:25 PM
yea i heard stuff breaks that way. im just goona get a 2 0r 3 in lift
Old Sep 21, 2009 | 07:42 PM
i heard of that too im looking into a way to get around that any ideas let me know
Old Sep 21, 2009 | 07:46 PM
NVANZEE's Avatar
the only way to get around the front end problems would be to get a 6in lift or get custom made cv shafts.
Yes you can do a 3in body lift with 2 people. I did, its fairly easy to do
Old Sep 22, 2009 | 09:55 AM
cueball's Avatar
cueball is on a distinguished road
I just got done with my 2" BL. It's not rocket science, just a PITA, just make sure you have the time set aside to get it done. It took me a full weekend to get it done by myself. Get a friend to help and it will go faster...
Old Sep 28, 2009 | 12:30 PM
gotti3586's Avatar
gotti3586 is on a distinguished road
yes we all know cranking the torsion bars too much will cause a lot of problems. but if u really take the time to grease the ball joints and wheel bearing, u can crank it up to 2" for a decent amount of time...i have a 98 s10 blazer and i've fit 31s under without rubbing with that...i'm in the middle of shackle lift...which is VERY cheap compared to a strate 2" suspension lift...but if u wanna do it right without no problems, suspension lift would be good
wlorton
Lifting Tech
16
Dec 26, 2009 05:05 PM
Tippman7641
Apr 6, 2008 07:20 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
texastrails
Suspension Tech
Jun 21, 2007 12:36 PM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
