4 door blaze on 35's?? regearing?
Old Aug 22, 2007 | 08:55 PM
cowboy717's Avatar
cowboy717 is an unknown quantity at this point
Default 4 door blaze on 35's?? regearing?
ok i'm thinkin about goin all out, so here it goes: about a 4 door 95-98 blazer,a 6 inch lift, 3 inch body lift, with 35-12.5-15's on 15x10 rims,, wondering about regearing too, what should i go down too?? 4.10??
also wondering about an LS1 swap too but that may come later
Old Aug 22, 2007 | 09:53 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: 4 door blaze on 35's?? regearing?
This should help
Old Aug 22, 2007 | 10:07 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Sounds like an awesome rig, get some pics up! Otherwise the link above should work good and help.
Old Aug 25, 2007 | 05:30 PM
cowboy717's Avatar
how much would a ls1 swap envolve?? how would the 4.3 handle the 35's??
Old Aug 25, 2007 | 07:13 PM
With the proper gears, you won't notice a difference with the 35's other than the obvious height difference. But that is ofcourse if you can get gears tall enough....
Old Aug 30, 2007 | 04:38 PM
cowboy717's Avatar
anyone know where i could find gears for a s10 blazer,, something like 4.10 or 4.56?? should that be low enough? what else would i have to change??
another question i have is would i have to regear if i swapped in a LS1??,, i think i may have found a nice blazer, but it already has a week engine, i'm thinkin that would be the ticket
Old Aug 30, 2007 | 06:30 PM
drperry's Avatar
I don't think the engine would complain if you had 35s on stock gears (figuring on 3.42s or 3.73s) but your transmission would still be much happier running 4.10s or so...
thegr81
Jan 22, 2025 07:32 PM
jagblazer01
Aug 22, 2009 04:46 PM
95BlazerLt4wd
Lifting Tech
Feb 29, 2008 01:36 AM
thegr81
Oct 19, 2007 08:18 PM
thegr81
Feb 21, 2007 05:49 PM
