5-6" lift thoughts
Old Nov 25, 2011 | 05:04 PM
NVANZEE's Avatar
I have seen a sfa blazer in person. He used coils instead of leaf springs. Said it rode just as good if not better then the stock ifs. It did very good on the trails too. He has somewhat of a build thread on this forum Never Enough.....SAS blaZeR2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old Nov 25, 2011 | 05:59 PM
neo71665's Avatar
I've never rode in a coil spring s-series but all the leaf sprung ones ride better than they did when they were lifted factory setup.
Until ord releases the coil spring setup imho that kinda rig is gonna take way longer to design than a leaf spring front end. Personally I don't see the point of wanting coils and links beside just to brag or on a rockcrawling rig. You can get more than enough flex on a street rig from leaf springs.
Old Nov 25, 2011 | 06:13 PM
NVANZEE's Avatar
yeah im not sure why he chose coils. To me it seems like they would ride better than leafs but i have no idea
Old Nov 25, 2011 | 11:27 PM
skotti's Avatar
skotti will become famous soon enough
Originally Posted by okiedoak20
and if i could see one done or atleast see a DIY or something i would think more seriously about it...
I live 3 hrs from you, your more then welcome to come look at my sfa...haha. I ran the 6" superlift last year. I sold it to a friend, so you could see that install as well. Install time is definitly greater on sfa.
Old Nov 26, 2011 | 12:29 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
i saw this blazer and talked to the guy. i think he has the 6" lift and is running 35's. he had to do quite a bit of trimming but i think it looks bad a$$.
Old Nov 26, 2011 | 03:08 AM
neo71665's Avatar
Spring over, spring perches that borderline lift blocks, and they still cut it up just to fit bigger tires. Makes me go hmmmm
Old Nov 29, 2011 | 08:35 PM
okiedoak20's Avatar
yea, Im really starting to lean to the SFA swap, looks like a much smarter move in the long run if done correctly(safely).. does any one have any
ideas on what to do about the transfer case, like i have the np236
the 4 button job,,, will that need to be swapped as well????
thanks every one.....
Old Nov 30, 2011 | 10:00 AM
skotti's Avatar
Swap out the transfer case for a 231 out of a first gen blazer. it will have the yoke already on the transfer case.
the time you put into swapping it to manual now, will be about the same amount of time required to diagnose why the push button is malfunctioning. You will also lose the auto 4x4 regardless.
Old Nov 30, 2011 | 10:26 PM
okiedoak20's Avatar
skotti,
Im guessing that will require a ECM reprogram??
Old Dec 1, 2011 | 08:53 AM
skotti's Avatar
no reprograming needed. most people completly remove abs system all together and install a metering box from a first gen as well.
if your speedo is way off after swap, ecm reprogram may be necessary to set gears and tire size.
pmzusmc
Apr 19, 2011 05:44 PM
ComputerNerdBD
Feb 28, 2010 11:30 AM
volfan4
Nov 28, 2009 08:04 PM
midnightmekanik
Oct 8, 2009 08:32 PM
cide
Mar 23, 2009 10:57 AM
