95 body lift? Help please!
Old Jul 5, 2011 | 11:15 AM
Blaze14's Avatar
Blaze14 is on a distinguished road
Default 95 body lift? Help please!
I just bought a 95 blazer and id like to put the set of 31's on it that i just got. ive been looking for a body lift but cant seem to find any for the 1995 blazers. is there any way to get a 3inch lift for a 95 without messing with the t=bar? any help or advice is apreciated.
Old Jul 5, 2011 | 05:27 PM
tibby's Avatar
Default .
Clicky
Reference the thread I linked above. They don't make 3 inch body lifts for 2nd gen blazers I'm thinking. But you can get a 2 inch body lift, there are two options for that range. And then you should easily clear 31's depending on the wheels you are using.
Old Jul 5, 2011 | 05:53 PM
warthogdriver's Avatar
i think you can get a 3 from earlier blazers and it will work but you will have to fab up a way to move the bumpers up with the body.
Old Jul 7, 2011 | 01:19 PM
Blaze14's Avatar
i found the 3 inch lifts for a 94, but do you have any ideas on how to get the bumpers up if i use that kit?
Old Jul 7, 2011 | 04:07 PM
Benedict1337's Avatar
you would have to make you're own bumper brackets. if you want to get 3" out of your torsion bars be prepared to spend a lot of money on front end parts, cv axles, hubs, ball joints, and some more cv axles, if you do any sorts of off roading you're alignment will be out of wack all the time, you will have a much stiffer ride. so the only lifts that don't leave you with a headache and a hole in your wallet is a body lift, 5" trailmaster, and 6" superlift.
or you can trade in your blazer for something more practical to lift
Old Jul 9, 2011 | 10:42 AM
Blaze14's Avatar
i doubt id be able to do that haha. heres another question though, would 3 inch t bar keys for the 94's fit on a 95?
Old Jul 10, 2011 | 09:57 AM
I beleive you can use those, cranking your tbars that high will reek havek on your front end suslension. I had my stock keys the whole way up and 4wheeling a lot will add to wear. I bought the best parts for the front end and they still wear out pretty quick. U'll be replacing your hubs and cv axles at least twice a year
Old Jul 10, 2011 | 01:02 PM
Blaze14's Avatar
yeahh, i dont want to be doing that. would a 2 inch coil spacer and a 2 inch AAL be any good?
Old Jul 10, 2011 | 07:33 PM
Coil spacers would work if ur blazer was 2wd, 4wd blazers dont have coils. And an add a leaf will lift your rear about an inch. Ive grown to hate torsion bars theres really no way to lift it without getting a drop down lift which is very expensive and alot of work involved and really doesnt give your suspension much more travel. The inexpensive lift that doesnt hurt your blazer and doesnt lift it to the sky is the 2" body lift. Then you can crank your tbars just a little and add a leaf or longer shackles and you have a 3" lift without hurting your suspension. You can clear 31's with 2-2.5" of lift
bschick
Lifting Tech
Oct 22, 2013 07:51 PM
ZoeZR2
Apr 25, 2011 02:34 PM
Tippman7641
Apr 6, 2008 07:20 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
