'99 blazer front end body lift options?
Old Dec 6, 2010 | 04:01 PM
Tinted's Avatar
Tinted is on a distinguished road
Default '99 blazer front end body lift options?
I know you can use shackles or extra leaf in the back, but are there any options for the front end besides the torsion bar crank? I know you can get keys that are angled differently than the factory ones, but how high can you really go?
I am looking to do 2.5 - 3 inch body lift and not sure what the best way is to go about it on the front end.
any advice is appreciated.
Old Dec 6, 2010 | 04:32 PM
mdehoogh's Avatar
First off, a body lift isn't the same as the shackle/leaf/torsion lift. A body lift (which comes in 2" or 3" kits) is made up of nylon blocks that lift the body off the frame. It doesn't require shackles or cranking the tbars. It also won't affect ride quality and won't add the stress that comes along with the suspension lift
As far as the suspension lift goes, the torsion bars are the only way (there are a few other options but they are considerably more expensive and involved). The keys help if you have worn out torsion bars by allowing you to crank them further than the stock keys and adjusting bolts will allow. It's recommended that you don't crank the bars more than 1.5-2". That amount of height can usually be accomplished with the stock keys which is why a lot of people don't bother with aftermarket keys.
Hope that helps
Old Dec 6, 2010 | 11:05 PM
Tinted's Avatar
yes thank you does that does help.
when you say 1.5-2 inches what is the reference point? what is the stock hight? I got my car with a messed up front end so I dont know what the stock hight is?
Old Dec 6, 2010 | 11:14 PM
69chevelle's Avatar
69chevelle is on a distinguished road
pretty much level with the rear
Old Dec 6, 2010 | 11:25 PM
Tinted's Avatar
so how much are body lift kits?
Old Dec 6, 2010 | 11:33 PM
69chevelle's Avatar
depends on what year your truck is, and where you purchase it from
locally from lordco I can get the 3" first get kit for 107 and 2" 2nd gen kit for 187 I think it was
Old Dec 7, 2010 | 11:20 AM
Tinted's Avatar
say if i do a 2 inch body lift with the blocks will I have to worry about anything being short and not reaching? im talking about hoses, lines, wires, etc?
BLAZER97LS
Apr 16, 2012 02:56 PM
Bravado
Lifting Tech
Apr 22, 2009 12:08 AM
Bang
Lifting Tech
Jun 1, 2008 08:25 PM
manfish
Lifting Tech
Sep 16, 2007 12:06 AM
Hypersona
Dec 15, 2004 08:56 PM
