Front lift options
Old Apr 20, 2009 | 10:10 PM
Bravado's Avatar
Bravado is on a distinguished road
Default Front lift options
I want to put a 2" lift add a leaf on my Bravada, then do the torsion bar 2" lift on the front. Is there any other method of lifting the front possibly another 2"? 'Cuz if there is, I can throw the shackles on the rear also and get a 4" lift.
Old Apr 21, 2009 | 01:55 AM
bandidolenny's Avatar
Nope. Just crank the t-bar adjusters to get about a 1.5" lift up front. I personally do not recommend using indexed t-bar keys like in the Rough Country 2" lift. You could always shell out the big bucks for a 6" lift but then you will have to do something about that all-wheel drive, no low range case of yours.
Old Apr 21, 2009 | 06:57 PM
Swain's Avatar
Swain is an unknown quantity at this point
Could also do a 2" Body lift which will give you plenty of clearance to offroad some 31's with no trimming, 32's with quite a bit of trimmings.
Old Apr 22, 2009 | 12:08 AM
okvortec's Avatar
There is only about a 0.5" difference in ground clearance with 31" tires and 32" tires, I'd just stick to lifting it 2" and putting on 31's.. Cheapest and Safest way to go.
Tinted
Lifting Tech
Dec 7, 2010 11:20 AM
manfish
Lifting Tech
Sep 16, 2007 12:06 AM
manfish
Lifting Tech
Aug 8, 2007 06:33 PM
manfish
Suspension Tech
May 14, 2007 01:47 PM
Arthur
Suspension Tech
Apr 16, 2007 06:40 PM
