Ball joint flip
Old Oct 2, 2014 | 09:35 PM
  #61
josh18657's Avatar
josh18657 is on a distinguished road
So I'm back on this lol. I'm replacing my ball joints this weekend. Don't have intentions of lifting it in the process, don't even plan on touching the t-bar adjustments. But let's say I might want to crank them in the near future to get that extra 1.5" in the front... could I install the ball joints flipped and run my suspension otherwise stock and be safe? Would it all align properly still? Obviously the joints would be at an odd angle when flipped and at sock height, no more odd of an angle I would think though on a stock non-flipped joints setup with the bars cranked.
I wouldn't do it. The way I see it is the flip just keeps the ball joint so it can stay straighter up and down and angled less. If this is correct then doing the flip on a stock height blazer would do the opposite and cause more wear on the ball joint.
Old Oct 3, 2014 | 03:46 AM
  #62
newguy's Avatar
I`ve been driving for 2 years with the flip and balljoint spacers without a problem
Old Oct 6, 2014 | 12:11 AM
  #63
okay thanks
that was sort of my thoughts too
it's back together now (well, the right side anyway, gotta get new bushings pressed into the upper control arm tomorrow for the left side...) and the ball joints are just going on as stock
Old Oct 6, 2014 | 03:29 AM
  #64
newguy's Avatar
Josh, incorrect, it spreads the control arms actually raising the the upper and lessening the the angle when you crank the tbars. I have done the flip and have 1 inch spacers between the the arm and ball joint. By doing this there is less cranking of the tbar also
Old Oct 9, 2014 | 03:25 AM
  #65
josh18657's Avatar
Exactly, but if I read correctly, they didn't plan on a lift right away so would be a stock height blazer with the ball joint flip.
Old Oct 9, 2014 | 11:11 AM
  #66
newguy's Avatar
Oh, didnt read the whole post, Sorry for correcting you Josh, My mistake
Old Oct 9, 2014 | 02:55 PM
  #67
josh18657's Avatar
Not a problem, I figured you just missed that part
I might be doing this to mine in the near future if I can find a cheap set of the spacers. I'll only be going the 1.5 inches lift in the front but if this helps save on ball joints it sounds good to me
josemateos
Feb 18, 2014 10:00 AM
Guntheone
Dec 4, 2010 05:59 PM
ejoy1220
Oct 8, 2006 06:45 PM
timetoblaze
Apr 17, 2006 12:47 PM
00ZR2BLZRGUY
Suspension Tech
Jan 1, 2006 08:12 PM
