Body Lift
Old Dec 25, 2012 | 04:18 PM
  #21
tibby's Avatar
Default .
Originally Posted by kenny100034
Alright gentlemen, its been awhile I know, but my PA body lift was given to me today for Christmas, the old man finally came around, he also made the mistake of offering me up his 31's. So now for the question, I have both stock 4wd rims as well as 2wd rims with the different offset, which rims would cause the least rubbing or am i just going to either way, I believe the 4wd's will rub sway bar and frame and the 2wd's would rub more fender. Also planning on 2" shackle and 1.5" tbar crank to help clear a little bit.
I believe it's all personal opinion. Go for what you like better. Personally I think a wider stance with tire sticking out of the fender well looks great! So I have 'Maro wheels with 4.5 or so inch backspacing. This backspacing is close to the 2wd rims. If you plan on doing the body lift and t-bar crank then it won't really matter which way you decide to go. You should clear both with 31s and no rubbing. If there is rubbing, it will be minimal after both of those lifting methods. Good luck!
Old Dec 25, 2012 | 05:39 PM
  #22
kenny100034's Avatar
kenny100034 is on a distinguished road
Alright thank you Tibby, yeah I kinda like the wider look too
Old Dec 26, 2012 | 08:24 AM
  #23
gitch93's Avatar
gitch93 is on a distinguished road
U will still rub some on the lower part of the fenders if u have a deep offset rim. I have a 2 inch body lift and 2.5 inch rough country lift with 4.5 inch offset rims and 31 inch tires and I had to mod the fenders a lot. If u do a lot of normal road driving it will be ok but if u hit a lot of bumps while turning it will rub a lot or if u offroad
Old Dec 27, 2012 | 05:58 PM
  #24
I'm hoping being that I have the Z85 package like Tibby does maybe I wont rub as much, but if i have to trim my fenders a little bit that is not a huge issue, appreciate the advice and warning
Old Jan 5, 2013 | 05:19 PM
  #25
smaiwald's Avatar
smaiwald is on a distinguished road
Does the fan hit the lower shroud after the body lift?
Old Jan 5, 2013 | 06:11 PM
  #26
Jamaroon's Avatar
no, they come with spacers
Old Jan 5, 2013 | 06:56 PM
  #27
tibby's Avatar
Default .
Not necessarily, it's on a blazer to blazer basis. My fan hit the shroud a bit whenever I would turn in reverse. Yes it sounds weird but that is what happened. So just watch out for little things that might happen. Didn't take too long to correct it, but it did make an annoying sound whenever it did hit.
Old Jan 5, 2013 | 08:27 PM
  #28
xgiovannix12's Avatar
Are you sure you dont have a bad motor mount? OR a bad tranny mount?
Old Jan 6, 2013 | 12:04 PM
  #29
Jamaroon's Avatar
x2, it should never hit the shroud, if it does I'd say there was something else wrong to begin with.
Old Jan 21, 2013 | 10:54 PM
  #30
timo98gmc's Avatar
timo98gmc is an unknown quantity at this point
I am ordering a body lift just wondering if there is interior stuff you need to do to get the body mount bolts out and does it mess with shifting linkage?
