Body lift finally on
Ok so after about 4 hrs of work i finally finished my body lift. i now have 2" shackles, 3" body lift and a slight t-bar crank. would love to know to know everyones tricks to raise the bumpers up or are new brackets my only choice. thanks... oh yea i have a buddy making sliders for me next week and gettin some new tow hooks made for the front this week too..
Before:
Reduced: 54% of original size [ 1023 x 764 ] - Click to view full image
After:
Before:
After:
looks good. what size tires are you running?
Very nice, for some reason they look bigger.
Gavin a he'll if a time configuring bumpers
If the front bumper mounts the same as mine, use 4 spacers and longer bolts (just like the body). The rear bumper used brackets on mine. Hope this helps. BTW, looks real good.
What about the side mounts where it has 2 bolts on each side?? Did u use those??Or just remove that bracket??
What`s about rubbing with those tires? I`m planning on doing the same, but if have to be sure that the tires don`t rub.
Did you have to trim a lot? Can you post some pictures of it?
Would it be better with 32"?
The op's truck is a ZR2 it came factory with more lift than a non ZR2 truck (and 31" tires were stock on them) for a non Z truck you wont fit 33's with the same added lift without rubbing issues.
Ya I could post u some pics if the trimming but it was very minimal. Like outstdr said I do have a zr2 which sits higher than normal. I will get some up for ya later today though
