Body Lift... Help!!!
Old Jan 2, 2012 | 12:57 AM
oldsbravada2000's Avatar
oldsbravada2000 is on a distinguished road
Default Body Lift... Help!!!
How is the shift linkage extended on 2nd gen Blazers with the Performance Accessories 2 Inch body lift? Mine is a 2000 4 door.
Old Jan 2, 2012 | 02:49 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
its not extended. they say its long enough for the lift. someone else asked about that then called PA and asked them and they said that they never had problems with the shift linkage for both the console and steering column shifters.
Old Jan 2, 2012 | 03:00 AM
Ok but my lift is 3 inches hopefully it will still work. Thanks for the info 97cherry.
Old Jan 2, 2012 | 03:03 AM
3 inch body lift?? unless you just accidentally pressed 3 instead of 2 then i dont know how you are getting a 3 inch body lift. but if it actually is a 3 inch lift then you will run into other problems.
Old Jan 2, 2012 | 05:13 AM
What other problems am I going to run into? I have the steering figured out and brake lines. I will have trimming to do for my fan but thats no big deal, I have all the oil lines figured out as well I am relocating them. I don't think there is anything else besides fuel filler neck.
Old Jan 2, 2012 | 12:35 PM
neo71665's Avatar
The shifter in 2nd gens is a cable, it'll be fine.
Using a 3 just make sure all the wires are long enough. Your only problems will be the bumpers, steering, and oil lines. Its not any harder than a 2 inch lift. People see 3 inch on a 2nd gen and without the research it can be a problem. You seem like you have looked at it and know what you are faceing
wlorton
Lifting Tech
16
Dec 26, 2009 05:05 PM
<3blazer
Suspension Tech
Jun 13, 2009 09:32 PM
Tippman7641
Apr 6, 2008 07:20 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
