body lift question
Old Mar 11, 2009 | 02:38 PM
Jfutch101's Avatar
Jfutch101 is on a distinguished road
Default body lift question
i have a 2000 s10 blazer and i wanted to know how big of tires i can put on it with out fender triming
also will i need to get new ball joints or will the speed odom be off?
Old Mar 11, 2009 | 03:19 PM
Sorry to say this again, but these are common subjects and have been discussed before.
Tim (hanr3) has a good article located in the Tech Article (DIY) section on tire fit vs lift. The pictures are gone, sadly, but the information is still there.
If you do a t-bar crank or put indexed torsion keys in, you will likely wear out your ball joints. The only reason to replace them is if they are bad, but anything much over 1.5" added lift will wear the ball joints out faster.
Your speedometer will need to be corrected if you change your tire size. Places are getting iffy about doing this. The dealer can do it as well as many other places with a full function scan tool, but they do not like to. The dealer, if willing, will likely charge you for an hour of diagnostic time at a going rate of ~$60.
Old Mar 11, 2009 | 03:47 PM
Jfutch101's Avatar
ok how off will the speed be like 10mph off or like 1mph also adding bigger tires that will give you less mpg correct?
Old Mar 11, 2009 | 03:53 PM
That question cannot be answered until you select a tire size to go to and list your stock tire size (label on your driver door).
Old Mar 11, 2009 | 04:15 PM
Jfutch101's Avatar
stock tire is 23" i want to put the biggest i can with a 3" body lift
Old Mar 11, 2009 | 06:13 PM
Stock tire is not 23". What is the actual numbers for the tire? There were two sizes offered on the 2nd gen S-series non-ZR2 trucks. 235/70R15 (28" tall) and 235/75R15 (29" tall).
Have you found a 3" BL for your truck?
Old Mar 11, 2009 | 10:00 PM
Jfutch101's Avatar
this is my truck when i first got it i believe its the 70r15 tire
how much lift will the 31in tires give with out a lift kit
i havent found a site yet with the kit do you know any??
Attached Thumbnails body lift question-l_60b7894622134dc3b47d1bef8fec2fec.jpg
Old Mar 11, 2009 | 11:08 PM
bammontana's Avatar
bammontana has a little shameless behavior in the past
What kit?
I do not believe they make 3 inch bls. You can get 2 inch body lifts, and the suspension you just crank the t-bar.
Old Mar 11, 2009 | 11:23 PM
bandidolenny's Avatar
If you do a torsion bar crank with no body lift you can run 30"s with the stock rims. 31"s with fender trimming or a body lift.
Old Mar 12, 2009 | 12:30 PM
Jfutch101's Avatar
ok ill get the 2'' body kit 31'' tires and ill put another 1'' on the torsion key
wlorton
Lifting Tech
16
Dec 26, 2009 05:05 PM
<3blazer
Suspension Tech
Jun 13, 2009 09:32 PM
Tippman7641
Apr 6, 2008 07:20 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
